Breather Tank - What should I do with the ports on TB/Intake
I have -10 bungs welded on both of my valve covers running to a breather tank.
I was going to just cap the ports on the valve cover, tb, and valley cover. (I also have the back of the intake manifold running to the brake booster).
However I've been reading some of the other setups and some people have check valves coming off the valley cover... going to i dont know where? Would I be ok just capping everything?
if you cap em all then you run the risk of pressurizing the crankcase under boost. do a search for Mightymouse' setup, there are several others too, but they will continue to pull a vacuum on the CC under boost. If capping them was ok, then why would the auto makers have designed pcv setups 25 years ago before they knew what emissions were?
I have two -10 lines running from the valve covers to a breathable tank. How am I going to pressurize the crankcase?
Exactly they made PCV systems to reroute the venting back through the intake to eliminate the oil mess created by engine blowby onto the valve covers. Which he eliminates by routing it to a catch can with a breather on it.
pressure comes from resistance. the vapor going into the lines, through the lines, into the can, then through the filter on the breather will give you some crankcase pressure, thats how.
the age old example, blow through a straw and see how much pressure you can make inside your mouth. its not that theres no where for it to go, its that it has resistance, which creates pressure.
other people have the check valve going to the charge pipes, it pulls a vaccum on the crank case when not in boost. other people take it one step farther by setting it up to pull vaccum when boosting also.
im currently running a lsx solutions dual catch can setup and was told by my tuner to ditch the setup and do just a single vented catch can to vent the crankcase since some oil will get back into the intake
1 Post
I second that... need some more opinions. I need to find a better way than the PCV vent I have right now. Any vendors out there that sell systems?
I have two breather tanks also. I added some extra mesh at the top to give the vapor something else to travel through so that way it doesn't end up blowing out of the filter and into the engine bay. It's worked so far.
Without a PCV system you will need to change the oil at smaller intervals.
what are you using to cap off the ports on the throttle body, ive had them capped with rubber caps and zip ties but they only last like a month before they get all cracked and ruined
on my set up i have a -10 an on each valve cover going to a vented breather tank.
on the ls6 valley cover you could put a 1 way check valve in in with or with out a catch can and run it to the black port in the front of the manifold.
or......
on the valley cover run that to the end of the air filter. the turbo will be sucking air threw the air filter and by having the line hooked to the valley cover it will be sucking air out the valley cover. but you should put some type of inline filter or catch can on that. also that will help the turbo drain
or......
