PT76gtsh Results (very pleased)
I nor anyone associated with the car would have ever thought it would run the number that it did tonight, heres the setup:
347
stock 317's with studs
TBSS LS2 cam
single plane with eldebrock elbow and TB
75lb injectors with dual walbros
th400 with unknown converter
3.23's in a stock 10 bolt with 325/50 mt's
as from gm stock suspension with spohn tq arm
truck manifold kit, 2.5 crossover, 3" cold side
pt76gtsh with 15lb spring in wastegate
93 octane pump gas with tr6's
98 pcm with 2 bar map tuned with efilive
347
TBSS LS2 cam
that **** is a turd. i know someone with a small shot on a stock bottom ls1 that will go to that ***!!!!!!!!!!!! Oh and on the boost ? i would say about 12-15 psi with head studs and rachet straps
turbo
nice job for the for first time out. I just ordered the pt76 billet for my front mount on my vette. Did you dyno it what numbers where you putting out at 15 lbs. Thanks Eric
