People who have or had valve float issues- come on in
I've been searching a lot about FI and valve float issues(or at least similar dyno sheet as mine). Well i didn't really find anyone who posted how they fixed it or if it was even valve float.
here is a dyno sheet so you can chime in with your .02 on my problem.
Some specs on my build are- forged 383, 9.8-1 compression, cleaned up stock heads with patriot duals, rear mount tc-78 @ 7lbs.
So any way if you experienced similar results on the dyno, how did you fix it, and does that look loke valve float?
i had a problem of the car once it made 12lbs of boost. the car would have a flutter sound and loose power and be flat.i changed coils,wires,plugs, and plug gap, also went to big stuff three and no change. then i checked valve springs that a local shop set up and said they where ok and would hande the boost. well just for the hell of it i removed one intake and one exhuast spring. checked the install hight and then seat pressure as well as full open. way to low on both. shimmed the springs but put them at .090 from coil bind.. went and ran it after that and the flutter was gone. so if it flutters then check your springs.
It is the XFI 280- valve lift 0.576 intake .57 exhaust, duration @ .050 is 230 I and 236 E, the springs are good to .650 lift and as i said before they are not shimmed yet, but will be hopefully today.
With such a mild cam, and springs good for 650...and such low boost. Nothing is pointing towards valve float.
Could be as simple as the plugs or wires breaking down. I assume your ignition system is in good order ?
I will have to check my tune for exact timing but i think its somewhere around 24 degrees @ wot??? and fuel, i have 42lbers and duty cycle is at 80%, intank 255 lph pump and a 255 inline pump, 94 octane.
With such a mild cam, and springs good for 650...and such low boost. Nothing is pointing towards valve float.i didnt really think it was a small cam for a lt1, but it has steep ramp rates.
the timing was ok, actually a little high at first then the tuner lowered it like 4 degrees.
opti has like 2500 miles on it since the 383 build plugs are new and i have new wires waiting ti go on, coil and ICM are older- 5 years old maybe.
Have you monitored your fuel pressure under load at WOT?
