Catch can / Valve cover breather
I have a prochager on ls2 with Catch can / Valve cover breather.
I have oil blow by.
If I remove the breather I blow my dipstick.
Does anyone have a picture explain how the catch can should be set up for a engine w/ prochager
thanks
I have oil blow by.
thanks
If you're blowing out the dipstick, there's a lot of blow-by. Disconnect the catch can, cap all the vacuum inlets and run breathers on both valve covers. No PCV is not going to matter much, because there is a lot of air moving through your crank case from the blow-by
But I will remove the catch can and add the pig tail back in to see if this helps..
