belt slip!! d1 procharger!
Old 05-03-2010, 10:41 PM
blk496ss's Avatar
Default belt slip!! d1 procharger!
my uncles gots a 99 z28 witha d1 n is having problems with the belt slippn off everytime he takes it out everything is aligned.. does anynone upgrade to a 8rib set up???
Old 05-03-2010, 11:01 PM
conan's Avatar
Is the belt coming off the pullies? Or is it slipping and causing low or incontinence boost and lots of belt dust?
Old 05-04-2010, 05:42 AM
dschmittie1's Avatar
yes most of us upgrade to either the procharger 8 rib or the SDCE 8 rib set up
Old 05-04-2010, 05:56 AM
2000SS1979's Avatar
If the belt is coming off then it most likely is not aligned properly. I ran a 6 rib set up for about 6 months with no problems, but I upgraded to the 8 rib setup for the hell of it and still had no problems.
Old 05-04-2010, 06:37 AM
01boydws6's Avatar
I'm still on a 6-rib but I machined down one of the stand off post's and added an extra idler pulley to get more belt wrap on the head unit pulley, seemed to work so far I was making almost 11lbs on the dyno and no belt slip issues yet. I had a belt alignment issue to fix but as far as belt slip there was none.
Old 05-04-2010, 06:45 AM
AFASTYZFR1's Avatar
If belt is getting thrown off the pulleys there is definitely an alignment issue
Old 05-04-2010, 07:33 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
I agree, the belt should never come off. With proper belt alignment and a new belt, the six rib kit should not give any problems at 6 to 8 psi of boost. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 05-04-2010, 08:18 AM
NoGo's Avatar
Belt alignment. I used a lazer alignment tool and some ingenuity to get mine aligned.
If you spend the time to align it properly you won't throw the belt anymore. The 6 rib may slip a bit, but you won't throw it.
Old 05-04-2010, 08:25 AM
AFASTYZFR1's Avatar
I aligned mine and my buddy's F1-C SS by eye and haven't had a single problem....but whatever gets the job done
Old 05-04-2010, 04:28 PM
stevieturbo's Avatar
A good straight edge is as good as any for checking alignment
Old 05-04-2010, 07:34 PM
Aster's Avatar
The 6 rib really is a waste of time with these systems, even at mild boost levels (~8 psi) the 6 rib will slip. The 8 rib is definitely worth upgrading to.
As for throwing the belt everyone above has it right. The alignment is off. Usually caused by missing the appropriate shim on the supercharger between head unit and the pulley. The 6 rib is a different shim width than the 8 rib I believe I was told. Check to see if the shim is in place, if not get with Procharger and they will know the exact one for that setup.
Personally even when I was mild with the P1 I knew the Procharger bracket wasn't going to be ideal for me so I made my own. Link is in my sig if you want to check it out. It wasn't the cheapest option, but it has maxed out D1's without skipping a beat.
Old 05-05-2010, 12:51 AM
blue00ZZleeper's Avatar
Running another procharger james? lol
Old 05-29-2010, 03:36 PM
SDCE's Avatar
Sounds like something might be misaligned slightly. Alignment is very crucial. Also check to make sure the bracket is perfectly flat too......
Old 06-01-2010, 07:10 PM
LSXFORMULA99's Avatar
i guess all my parts are good because i didnt have to align anything. just bolted it all together. i have a 8 rib setup
Old 06-01-2010, 08:16 PM
NXPRSS's Avatar
8 rib setup is the only way to go!!
Old 06-01-2010, 08:42 PM
98legendws6's Avatar
He should upgrade to the 8 rib and get the SDCE Bracket while hes at it.
Old 06-02-2010, 09:56 AM
LS1RedZ's Avatar
Yeah, you should definitely check out Aster's bracket setup.
Quick Reply: belt slip!! d1 procharger!
