Bigger wastegate recomendations?
Have a tial 38 now.. its too small. 10psi spring making 11 and the boost is going crazy when I try and turn it up.. bouncing up and down. Anyone have a recomendation for a bigger wastegate that will bolt in just like the 38? I dont wanna change the flange if i can avoid it.
You can pretty much forget about getting something bigger that will bolt up that will make much of a difference. Might as well just bite the bullet and get a Tial 44 or 46 and do it once, do it right. The Precision 46 is a reallly nice piece as well. It comes with all the springs you could ever need, vbands, flanges, everything, and it's cheaper than the Tials.
The boost controller was a cheapy that i got from someone.. just a ebay one. I barrowed a friends MBC thats really nice so Im going to try that out. I took the cheap one apart.. the spring iside looked a little bent but other then that seemed ok. My guess is a bad BC
Thing is, i didnt have an issue before with a much less efficiant exhaust wheel. I am sure my back pressure was much higher. With this new turbo its flowing much better I dont see how that could be the issue. I am going to try and the new MBC and report back.
