347 vs 374
347 vs 374
Are there any cons to going to a longer stroke when building a LS1 for FI. I know a lot of guys stick with the 347 with the LS1 to keep the thicker walls but for a mild build would there be any harm in going with the longer stroke and punching her out to say around a 374.
I searched and didnt see any thing that said any thing bad about going with the 374 on a FI set up. The bore would still be a 3.905 the same as it would be for a 347 the only diffrence would be the stroke of 3.900 vs 3.622 with the 347. Not saying your wrong just wanting to know why the longer stroke would hurt it.
I have been told that the 383 is not good for turbo set ups. I dont know if the stroke is just too long or what it is. I was hoping some one would shine some light on the mistory for me.
There are alot of people on this form making really good numbers with a 383. Im thinking of going with a 383 on my build.... I especially like the low end torque a 383 gives out.
They are.... I personally dont want an iron block. But thats just a personal preferance.
The one time it did make to track it was running on 7 cylinders as it had burnt plug wire found out after fact. Way wrong torque converter. However i do have a new bigger cam and a py3400 converter and a rossler trans brake to get installed now. Those numbers were on 20psi , made 750/750 ish on 14lbs .Hopefully cam will raise those numbers slighty and bring boost in faster.
