Will this turbo work for my setup?
Will this turbo work well with what i've got done already? Below is everything thats been done to my car. Here is the specs of the turbo;
T3/T4 Turbocharger
Turbine Turbocharger
Oil cooled only
6 blade propeler
Compressor Specs :
3" Compressor Inlet
1.990" or 50.55mm Minor
3.000" or 76.2mm Major
Compressor .50 A.R.
Compressor 57 Trim
M12 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
2.25" Outlet
Turbine .64 A.R.
Turbine 76 Trim
2.207 " or 56.06mm Minor
2.567 " or 65.2mm Major
Exhaust Outlet Flange with 5 bolt design
Can be modified to use external or internal wastegate.
T3/T4 Turbocharger
Oil cooled only
6 blade propeler
Compressor Specs :
3" Compressor Inlet
Compressor .50 A.R.
Compressor 57 Trim
Turbine Specs :
T3 Type Turbine
11 Blade Type
2.25" Outlet
Turbine .64 A.R.
Turbine 76 Trim
