Found my issue? Bad Plugs?
Old 05-12-2010, 01:18 PM
01SOMm6's Avatar
Default Found my issue? Bad Plugs?
Car has been missing at idle and acceleration(really bad) Runs like poop.
I was getting a check engine light for bank 1 too rich. So I decided to check my Sparkplugs. 1st plug I go to check and its so loose I can just unscrew it with my fingers(drivers side)?? WTF. I pull it out and its soaked in fuel. I check the how tight the rest are and they are fine. I didnt want to get to into pulling stuff apart so I put everything back together. I have TR6 in it now and Im going to try the 7s. Im just trying to find somewhere in germany that carries them.
Whats a good gap for them?
Old 05-12-2010, 01:23 PM
Orangemagic's Avatar
Pending on what kind of boost your running a good gap would be .28-.032. I would also jump to a #7 plug.
Old 05-12-2010, 01:50 PM
01SOMm6's Avatar
Right now Im seeing 10-11lbs.
Old 05-12-2010, 09:53 PM
What are the current gap on the plugs your running? with 10-11lbs a .030-.032 would work best for gap.
Old 05-12-2010, 09:56 PM
Ws6kid.'s Avatar
well im not boosted...
but when i used to have bank one too lean
and random misfire
it was an intake leak.
just giving my .02....
Old 05-13-2010, 03:34 PM
01SOMm6's Avatar
I dont remember the gap. I had an issue once before where The fuel line on the rail popped off and the car died on me. Somehow messed up the plugs? Changed them to autolite that where equal to the tr6s and fouled them right off the bat. Put in TR6s and it ran like crap put octane booster and it slowly got better.
how it happened this time is hard driving through corners downshifted one hard time and it just started missing and falling on its face. The same day I had the car on a dyno and had some high speed runs on the autobahn.
Old 05-24-2010, 11:07 AM
01SOMm6's Avatar
Update on this-
Replace the plugs with the 7s gapped at .030. Idled perfect for about 10 mins while I let it warm up. Reved it a couple times and it was fine. Went for a test drive, about 30ft out from the garage I heard a pop noise and then the car started running like crap again?
I havent had time to work on it since but any ideas whats causing it?
Old 05-24-2010, 12:35 PM
CarsandWomen's Avatar
boost leak?
Old 05-24-2010, 01:34 PM
01SOMm6's Avatar
Dont know where a Magnacharger would leak boost from?
Unless I was leaking from where the actually charger bolts to the heads?
Old 05-25-2010, 05:57 AM
OUTLAWZ RACING's Avatar
check your crank position wires and unit. also what is the afr at idle?
Old 05-25-2010, 06:02 AM
lordrazo's Avatar
i would prefer to gap at .035 no more than that it will blow out your spark i feel its a sweet spot so you at least still have a good gap for a bigger spark few thousands accually make a differance
Old 05-25-2010, 08:10 AM
yes, carefully inspect the case, it may have a hairline fracture that opens up when it gets hot, or start moving air, also yea im with OUTLAWZ, check wiring to all sensors
Old 05-26-2010, 02:55 PM
01SOMm6's Avatar
I will check The crank position sensor. I need to recalibrate my wideband but it was always bouncing around in the 14s and sometimes low 15s.
Old 05-26-2010, 04:20 PM
litle88's Avatar
Im sorry but i am having the same problem right now!
I am fouling out #5 and #4 and #8 is detonating
It breaks up bad around 2k rpm.
I started by buying new Tr6's and msd wires= No good
Bought a new coil for the fouled plugs = No good
I swaped the coils to different sides = No good
I had a o2 sensor go bad it was really fouled on the drivers side so I bought a new one and 8 new Tr6's = No good
I sprayed brake cleaner in both sides of the intake for a vaccum leak = no good
I put a propane torch near the intake on both sides (without turning it on of course) for intake leak = No good
I swapped PCM's with my tuner at StraightLine and he loaded my tune to see if it was my PCM = No good
I will be letting it cool down later and then im gonna be getting a crank sensor on friday to see how that goes. If it doesnt its down I think 2 things a blown head gasket or a cracked intake. I hope not
Goodluck with your ride and keep us posted, Sorry for the small highjack!
Old 05-26-2010, 05:31 PM
01SOMm6's Avatar
No Problem. I just replaced my headgaskets with cometics. Ran great for a couple weeks. I had this problem before went through 1 set of TR6 then I went through autolites then put TR6 in and added octane booster and it went away. I dont know what the problem is now. The motor and heads are pretty new as well as the Charger.
I might just part the car out or sell it for a good price. I dont have the Time to deal with it.
