engine failure after rebuild
had to rebuild my motor 2 times. losing oil pressure after i try laying into the throttle. have had 2 different machine shops work on it. it appears the thrust bearing is being taken out.....like the crankshaft is being pushed forward and causing excessive heat and causing bearing failure.
I have a vigilante converter and it has anti-ballooning plate. i was also told that to much line pressure in the transmission could cause this problem. using factory crank, compstar rods and H series bearings. Using arp main studs and block was not line honed. Engine failed both time in about a week any feedback would be greatly appreciated.
check mods on SIG.
check mods on SIG.
+1 with checking the converter, going from N/A to FI would require a different converter. When choosing a converter that is one of the things they ask and why they need details on your set-up and goals when they make one for you. When I got mine from Yank I pretty much had to tell him everything I did with the car and what it was being made to do
