Are the callies dragonslayer cranks not strong enough for supercharged applications
i have broken my crank and now wondering why? has any body else had this problem, what should i do to solve my issue, pics below.
belt drive is 50mm gilmer. berings looked fine , transmision is 4l80e with yank 3400 stall
how was the tune? nitrous? its very odd to see such a clean snap like that on a high quality crank. at 1100hp youll have super high quality rods and pistons, which leads me to believe this is possible: you had a very early detonation in one cylinder, the rod and piston held up cuz theyre awesome like that. that one piston fired so early it rotated the crank backwards vs the other 7, pow pow chicken.
7 Second Club
I ran the Callies Compstar up to 1132rwhp and never had it fail... This year on my rebuild we went to the Magnum, but that is only because we are pushing up to 1500ish on the RWHP number.
I've always had good luck with callies...
Hold on! Now you're comparing apples to oranges. You can in no way compare the stressed of a turbo car (your car) to a SC car. The torque that is placed on the crank snout with a big cog drive blower CAN twist cranks in two whereas as turbo car does not have this added counter-torque. As Shawn@VA Speed mentioned, this is not freak occurence. Big cog drive blowers on LSx motors pushing BIG power is a relatively new frontier and apparently things aren't quite up to par with say the SBC crank with BBC snout...there's obviously a reason for that. I'm regearing my F2 cog with my new setup aiming for 1500rw and Shawn's putting in a Lunati Pro Series crank...hopefully I won't see this issue.
There is nothing wrong with the Callies crankshaft-it is a very capable forging that i have pushed to 2000hp in an ls engine.The stress that the supercharger puts on the crank is much different and the normal stresses a crankshaft sees,the is the reasons for such things as crankshaft supports.The placement of the belt also makes a huge difference-the further forward of the engine,the worse it is.The Lunati forging seems to have a little more material in the overlap area,which should help greatly.
