anybody running a turbo timer?
back in the day before i knew anything about turbos i remember a lot of guys running turbo timers to make sure the oil cooled the turbo before the engine was shut off.
i also seem to remember somebody talking about the WRX's having a design so as to slowly drain through the turbo after the motor was cut, so as to further cool and lube the turbo and prevent any damage.
ive got a 60 series tnetics and im remembering those convo's and just wondering
ha, me and my pops were just talking about this. i would like to know also...they sell cheapo's on flea bay but as long as it works i dont see a reason not to buy this. can some pros chime in???
I would say most lsx turbo guys are not running them. The idea is that after running a turbo hard then shutting it down, the housing temp is so great that it can bake the oil in the lines therefore plugging them up or causing restrictions. You see this more on imports because they are running their turbos harder since that turbo is smaller and spooling at low rpm. On most lsx turbo setups, you're only going into full boost for very short periods, not depending on the turbo all the time to get the car in motion, so the turbo is not running super hot and therefore doesn't need a prolonged cool down time.
Moral of the story: if you just made a pass or have been beating on the car (in boost alot), cruise around or let it idle for 5min before shutting it off and you won't have any problems. My TA was a TT daily driver, I lived by this principle and never saw any turbo failures or oil line issues.
yeah ricers run them because they think they look cool when they get out of their car and it cuts off by itself. when do you really make boost then park your car immediately afterward?....spend your money on something useful
I have close to 50K on my turbo SHO and the original PT67 is still in perfect condition as far as I can tell. Never ran a turbo timer and I run the car very hard.
edit: after you put your car in park or once you park it is general practice to let the car sit for 2-5 sec to let the turbo spin down as much as it car before you turn the engine off because you don't want to cut the oil supply which it is screaming especially for a non ball bearing unit.
A turbo timer is really only pocket change compared to the rest of the build so why not add the extra insurance?
I run one in my V6 Eclipse and it's kind of nice not having to sit there and wait for the EGT to fall after that last pull.
