single turbo dual exhaust?
i was wondering if anyone was running dual exhaust with a single turbo,and if you are can you post pics of your set up. would i be loosing power by doing this or should i run a single 3" pipe all the way out? i want to run dual pipes just not sure the best way to do it. thanks kev
what size is the turbo outlet? You want to ensure the combined area of the two pipes is larger than the area of the outlet.
I split my 5" into dual 4s, but ran in way that isn't for a streetcar (fender exit behind the front tires)
