Synthetic or non synthetic oil for turbo setup?
Thats why i ask! you never know what people are trying to tell you! i figured a synthetic would work very well on a turbo..and obviously by the replies it seems to be the way to go..ill stick with the mobile one synthetic i never had any issues with that stuff but i may try the 15w..
Thanks!
Thanks!
I was running rotella untill the last change, i switched to synthetic 10-30, and i plan on switching back to synthetic rotella, the oil seemed to last longer and the car smoked less with the rotella in it
Rotella works good for quite a few guys. It is not however ideal as far as viscosity goes. A group IV or V synthetic of the proper viscosity PCMO (5w-30 or 10w-30, depending on brand) will outperform rotella in a gasoline motor. Granted for most here it is overkill big time, as quite a few conventionals will do just fine with a turbocharged motor.
Rotella is a very good diesel oil(HDEO). Any oil will work as long as it is a current formula. The point is there is an ideal oil for every engine.
synthetic does not break down
welp guess if thats true, sounds like a good reason to use it to me.. I deffinatly cant tell my pops this..he'll go 11-14k per oil change with what ever cheap **** walmart puts in his new Tundra..if i told him synthertic never breaks down..good chance hed never change his oil hahaha
