stock crank and block, forged rods pistons - how many PSI?
Old 05-28-2010, 02:24 PM
Eagle02's Avatar
Default stock crank and block, forged rods pistons - how many PSI?
Just like the title says.
The combo as it sits put down 643/673 @ 13.5psi on pump gas. Mixture was dead nuts, I think we only ran 16* timing IIRC.
How far do yall think I can push this thing on pump gas?
  • PT78
  • ARP hardware everywhere
  • studded heads, GM 6.0L MLS gaskets
  • forged rods and pistons
  • 9.5:1 CR
  • stock 317s w/dual springs
  • stock LS6 and 78mm TB
  • TH400
  • plenty of fuel system left to go bigger. IDC is ~75-82% max
Old 05-28-2010, 03:12 PM
viper9403's Avatar
I'm making around 20# with an F1A on my built 347 with patriot stage 3 317's and have yet to have an issue on pump gas and meth. I've only had about 14* of timing in it thus far.
Old 05-28-2010, 03:16 PM
Eagle02's Avatar
Wow. That's pretty impressive. The meth probably helps quite a bit I bet. I have yet to get a meth kit on my car...
Wonder how much that's buying you.
I bet it puts down amazing numbers @ 20#!
Old 05-28-2010, 03:48 PM
viper9403's Avatar
I'm not sure, has yet to be on a dyno.
Old 05-28-2010, 04:07 PM
Restricted User
98Z28CobraKiller's Avatar
  • PT78
  • 9.5:1 CR
  • TH400
On pump gas, I run about 16 psi and 13* of timing with a very similar setup. My top end flows more air with the bigger heads, intake, TB and PT88. Car runs high 9.4's in this trim. When I turn it up to 19-20 psi, I drain the pump gas and put in C16. Also bump the timing up to 17*. I know that I could go way higher on the pump gas but I am already about out of gear and out of faith in the stock PCM.
Old 05-28-2010, 04:55 PM
Eagle02's Avatar
That is excellent info. Thx!
Old 05-28-2010, 06:50 PM
cbr600rx7's Avatar
You are my hero of the day. Great numbers for pump gas.
Old 05-28-2010, 07:36 PM
Eagle02's Avatar
Not sure who you're speaking to, but I like the message!
Old 05-28-2010, 08:19 PM
ou812/z28's Avatar
i have an s74 with 317's ,stock crank and 6.0 iron block. scat rods and wiesco pistons.on pump gas with 17degress on the big end it runs 9.40's at 148 on 12lbs. looking in the near future to experiment with e85.
Quick Reply: stock crank and block, forged rods pistons - how many PSI?
