factory rev limiter
Old 06-08-2010, 07:38 AM
Tzion_ben_Arthur's Avatar
Default factory rev limiter
I do not have a stand alone rev limiter, just factory ECM using efi live cos3. What happens if I hit the limiter under boost? I believe the factory ecm cuts fuel not spark.
Old 06-08-2010, 11:09 AM
Gingervitis Addict
slow67's Avatar
In theory it should be ok as long as you aren't spraying meth. The reason it should be ok, is since you remove ALL of the fuel, its technically not lean.
Old 06-08-2010, 11:27 AM
Thank you. I did not think of it that way.
