holset H2e turbo....17cm exhaust housing
Old 06-13-2010, 04:08 PM
70cartruck's Avatar
Default holset H2e turbo....17cm exhaust housing
anyone on here used one of these......got a nearly new one for free....thinking i will try to use this instead of spending $$$ on a mpt70......
thanks...
Old 06-13-2010, 07:51 PM
99Z28LS1's Avatar
thanks...
already cutting corners
Old 06-13-2010, 10:03 PM
70cartruck's Avatar
well since i made the post i found out that a h2e is a twin brother to a hx50....both using the same flange...a t4i....they have different configurations of both and i found out that mine has a roughly 67mm wheel on the intake side and a 17 cm exhaust housing....cant find an exact measurement on the a/r....the intake wheel seems a little small at only 66-67mm.....
im not cutting corners....just seeing why anyone would have a problem running a holset style turbo....there are all kinds of import guys using them....
Old 06-01-2011, 10:55 AM
Ford_Assassin's Avatar
Updates?
Old 06-02-2011, 12:27 PM
MrPotatoeHead's Avatar
17cm is the actual exhaust measurement. Holset doesn't use the standard ar ratio.
Quick Reply: holset H2e turbo....17cm exhaust housing
