stock 06 gto A4 with F1 procharger 13-15psi
what life span do you guys thank the stock bottom end, tranny, and rear end will be??
i called procharger they said the biggest pulley i can get on the blower is 4.75 under stock hood they said it will make 13-15psi thats spinning it to 6400
i have the head unit from another project so i would like to reuse it on this build, I plane on building my own brackets to mount on the engine to move the blower back in the engine bay, so i can try using the same factory belt drive line, then maybe i can get a bigger pulley on the blower
the only thing done to the car is a tune with hp tunners
slp exhaust deleted cats, and 80lbs injectors
this is a weekend getter not DD
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
i have always wanted the wifes goat FI, so now i have the chance, just reuse what i already have, the weak links will be built in time but i need to get the last project sold to fund this one
LS1Tech Sponsor
I have a lot of information at this link that should answer some of your questions. Many 10 bolt rears have been broken with the stock horsepower, especially if it is a manual transmission. Bob
__________________
the blower is on and we tuned a bit tonight
I custom made all the brackets so i could use the factory 6rib drive line, it all works perfect, i have the stock crank pulley pined and a 4.25 pulley on the blower.....
i also put a waste gate on the piping to keep the boost down to 10psi, what little we did tonight it made 8psi right at 3k the car didnt feel right so i let out, we will have to put the wideband in tomorrow to see what all its doing
that f1 on the car is a dead give away there somthing under the hood
My P1 took the lesser part of 2 days of normal driving to blow out the 60E. That was on a lot less cubic inches too!!!
LS1Tech Sponsor
__________________
well took the car out last night, when it got to full boost holy **** it felt good
the wastegate is working great its opening around 10-11psi and staying right there, the only thing we are having problems with is on the lower rpm when I roll in to it it goes pig fat (9s) and it wont pull up threw the rpm range, but if i floor it and it down shifts it will go straight to 5500 and it pulls hard in tell shift point (6200) but it goes lean 13s on big end (stock fuel pump) we have messed with the pe table the maf, we are getting there but just time consuming, i would like to go to 2bar for the easy of the boost enrichment
this is on 8 degs and it was going lean cant wait in tell the fuel is there, then bump timing,this will be a sick ride
LS1Tech Sponsor
__________________
