Got Boost Sag?? Don't need that fancy EBC!
Old 06-18-2010, 04:32 AM
NAhookup's Avatar
Default Got Boost Sag?? Don't need that fancy EBC!
Not sure if anybody has this type of problem in the V8 FI world, but my experience with I4 Turbo cars have led me to post this up, its quite helpful for lots of guys! So if you're having trouble with boost tapering off, specifically maybe some folks seem to be having boost curves that look like this, and perceive it as justification for the fact that their manual boost controller just isn't cutting it, and they need to go out and spend money on a fancy electronic boost controller.
So, does that look familiar? If so, save your money. Fixing this problem is going to cost you about $3.
First, let's take a look at why this is happening. Here's a simplified diagram of your turbo system, where we have the turbocharger itself, then the intercooler, and then the throttle body.
Point "A" in this system is where a lot of folks have their boost controller connected. It's that nipple that came from the factory on the side of your compressor housing, probably with a hose already attached between it and the wastegate actuator.
Well, that's just stupid.
What's happening here is that your boost controller is in fact maintaining a constant level of boost, however it's doing it in the wrong place. Specifically, it's maintaining a constant level of boost at the compressor, but that's not what your engine is actually seeing.
Confused?
Yes, behold the simple drinking straw. Solver of great mysteries.
Here's a quick experiment. Stick a drinking straw into your pie-hole, and blow through it. Not too hard, very gently in fact. Very, very gently. This ain't Hustler's mom we're dealing with.
Feel the resistance that the straw is offering? No? Of course not. At the rate at which you are blowing into it, the straw is not much of a restriction at all.
Now, blow harder. And now you start to feel the straw fighting you.
A funny thing happens when we try to flow a gas through a restrictive orifice. The more we try to flow through the restriction, the more restrictive it becomes. In practical terms, at low rates of flow, we get very little pressure loss across the restriction. As flow increases, so does the pressure loss. And it's not linear, either. The magnitude of pressure drop increases almost exponentially with flow rate.
Now, it may not look like one, but your intercooler is a drinking straw. A large, heavy, aluminum, multi-faceted drinking straw. Or, at least, it exhibits a lot of the same characteristics as one. So, back to the diagram:
Say that we have our boost controller set such that we see a peak of 12 PSI in the intake manifold. At 4,000 RPM, we reach that point. We are, incidentally, flowing about 130 CFM through the intercooler (our engine has a 100% VE at all speeds) and we're loosing about 1 PSI across the intercooler. So while the pressure at point B is 12 PSI, the pressure at point A (which is what the boost controller is seeing) is actually 13 PSI.
Now, we increase the speed to 7,000 RPM. At this point, we're moving about 220 CFM, and yet, what's this? The pressure drop across the intercooler has increased to 3 PSI! We didn't even double the flow, and yet we tripled the drop. (Well, I'm ignoring the fact that these are relative, rather than absolute pressure values, but you get the idea.) So now, even though the MBC is faithfully holding 13 PSI at the compressor, we're only seeing 10 PSI at the manifold.
The solution here should be pretty obvious by now. Move the boost controller from point A to point B.
By doing this, we are now telling the boost controller, in essence, "Hey, I want you to do whatever it takes to maintain a constant pressure at point B in the system, and to hell with what's going on over at the compressor." And it will comply. (Boost controllers are pretty simple-minded like that. They don't question orders.) Specifically, it now does not matter what the drop across the intercooler is, at least insofar as your actual manifold pressure is concerned. As drop across the IC increases, the boost controller will cause the compressor pressure to increase accordingly. So by the time you get to 7,000 RPM and are experiencing 3 PSI of drop across the IC, the pressure at point A will be up to 15 PSI, and you'll still be getting your 12 PSI at the manifold.
And here's everything you need to make it happen:
Yup. One 1/8" NPT hose-barb fitting. About $3 at your local ACE Hardware store. Drill ye' olde hole into the pipe which leads up into your throttle body, install this fitting into it, and plumb a hose from there to your MBC. Using all-silicone tube? (***.) Well, just drill a hole in the colid-side end tank of the IC itself. Anywhere is fine so long as it's after the IC core, and before the throttle body.
You'll probably have to turn the MBC down just a tad in order to achieve the same peak boost you had before, as it's no longer having to factor in even the smallest IC drop.
Hope this could help out anybody having trouble with this problem?
Old 06-18-2010, 08:04 AM
Big_Bird_WS6's Avatar
i get my feed line off the intake. that works great.
Old 06-18-2010, 09:41 AM
buick_lsx's Avatar
mines off the turbo...but i dont lose any boost in the upper rpm range.
just an import thing lol
Old 06-18-2010, 10:38 AM
LS1Silverado05's Avatar
I've had mine on my intake pipe just a little before the TB from day one, because in my thinking I said...well, I dont need to see vacume but I do want to read what the MOTOR is getting, not the what the Intercooler is being fed, so thats hows I've had mine. I get told Im wrong all the time "just because".
I guess it clearly works either way, and as long as you are dialing your boost controlle rup to what you want on your gauge and your gauge is reading from the right place, its going to work.
Old 06-18-2010, 12:22 PM
NAhookup's Avatar
Well the whole point is that everybody usually goes with the compressor housing nipple to get boost signal for the boost controller, that works yes, but all they are doing is controlling that 10psi on the compressor housing. When in theory you are having to crank more out of the turbo to generate 10psi at the manifold. Lol most guys dont think about, "lets control 10psi at the throttle body"...
Most of you guys proabably are on top of the game as I figured, but just in case somebody has any boost sagging problems this might help
Old 06-18-2010, 12:47 PM
XtremeDime's Avatar
I hear about people using the nipple on the turbo and lose 1-2psi even on an ls1. Ive always had mine hooked up to where the EVAP was and have seen constant 8psi.
Great write up explaining everything though!
Old 06-18-2010, 12:53 PM
NAhookup's Avatar
Thank you sir.
Quick Reply: Got Boost Sag?? Don't need that fancy EBC!
