AES Racing Engines FI Shortblock sale
Old 06-30-2010, 07:39 PM
AES Racing's Avatar
Default AES Racing Engines FI Shortblock sale
We've worked with CP Pistons on a custom boost application piston for LS engines. Quite often the typical 408 engine is either too big for the head unit used (ie 76mm turbocharger or D1SC) or it leaves some dimensions of the piston to be desired.
Combining Callies C-Series 3.825" crankshaft, compstar H beam 6.125 rod with a 1.200" CH piston, gas nitrided top ring puts together great combination of parts.
Using 1.200" compression height we're able to put more strength into the ring lands also improve the skirt design.
These pistons include .180" wall thickness Chromoly piston pins package.
We still offer 408 boost engines, however this gives you another option.
390ci shortblock package Independence day pricing till July 10th, $3599 + shipping
6.0 Iron Engine block
Callies Compstar C-series crankshaft 3.825" stroke
Callies Compstar H beam connecting rods
CP Pistons 2618 forging -15cc D dish
NPR gas nitrided piston rings, napier 2nd ring
King HP bearings, durabond cam bearings
All parts are thoroughly cleaned before assembly
Crankshaft balanced and polished
Line honed main journal
Resurfaced cylinder deck
Torque plate honed bores
Assembled in our clean, dedicated, engine assembly room.
Add dowel pin mains and piston coating (moly skirt/ceramic dome for $500 till July 10th only!
upgrades are available
  • ARP Main and head studs
  • Piston Coating
  • Gas ports (lateral or vertical)
  • Callies Magnum crankshaft
  • LS2 Aluminum Block upgrade
  • Block O-Ringing is available
  • Main Cap Dowels also available
  • Billet main caps and installation
  • Special pricing on all gasket kits, valve train and cylinder heads.
Longblock package $5999 - 390ci shortblock package with the addition of
-Ported '317' GM castings, assembled with stainless valves and Patriot Gold dual springs
-ARP head studs/ ARP main studs
-GM MLS gaskets
-Comp Cam/LS7 lifters
-JP Performance double row timing chain
Heads are assembled, installed, camshaft degreed
Heres a pic of the 390ci pistons we've collaborated with CP pistons to have produced
Attached Thumbnails AES Racing Engines FI Shortblock sale-cppiston39022.jpg   AES Racing Engines FI Shortblock sale-bullet390.jpg
Old 06-30-2010, 10:12 PM
1CAMWNDR's Avatar
Very nice. I wonder if that is a cheaper option than a 4.155" LSX block and a polished stock 3.622" crank (392"). In the long run I bet it is cheaper since you'd need big bore heads with the LSX 392 but normally available 4.03" heads with the 6.0 block. And I bet that the 6.0L block plus the new crank and custom pistons will not even be the same money as a new LSX block bare.
Again, VERY nice set up.
Old 06-30-2010, 10:33 PM
AES Racing's Avatar
LSX block itself is expensive, and reasonably heavy.
I'd rather use a crankshaft with a keyway, you could mill a keyway into the stock crankshaft for the balancer. The Compstar c-series crankshaft includes this.
Old 06-30-2010, 10:45 PM
buick_lsx's Avatar
yall def have some nice setups and combo's...this winter im def. getting a shortblock and cant wait to see what specials yall have then...keep up the awesome work
Old 07-01-2010, 02:01 AM
FrankSS's Avatar
what kind of power can this engine handle reliably? could an F1C or R run on this daily if needed?
Old 07-01-2010, 06:36 AM
OUTLAWZ RACING's Avatar
Looks like a ross piston. But nice build
Old 07-01-2010, 02:38 PM
AES Racing's Avatar
Handle anything you would put through a 370 or 408.
Infact i'd say you would be pushing coolant before you had
shortblock destruction.
Old 07-01-2010, 02:45 PM
AES Racing's Avatar
BTW just added, gas ports are an option.
I'd recommend lateral gas ports if interested, $120 option.
Old 07-08-2010, 12:28 PM
AES Racing's Avatar
Pistons have arrived, heres the result.
CP pistons are used everywhere from import to Mike Edwards NHRA pro stock, here we have a high end pro stock piston next to our LS boost piston, built by the same group of people on same machines, less machining steps goes into the piston we've collaborated on, basically we left out CNC lightweight milling, to keep the cost affordable, main goal is building a shelf piston for some serious boost. Works out to 390ci when used with 3.825" C-Series crankshaft or 383ci with 3.75" Callies Magnum Crankshaft, either crankshaft can be used, i'd change rod length to compensate if needed.
Old 07-08-2010, 02:48 PM
1CAMWNDR's Avatar
Damn. If I am ever lucky enough to build a boost motor I know where I will call .
Old 07-08-2010, 04:44 PM
gnx7's Avatar
What is the cost to Oring the block?
Old 07-08-2010, 04:57 PM
Z06_Fan's Avatar
Very nice offering here!!
I can't wait to see more of these hitting the streets.
What forging is this compstar crank? Any idea on where to get more info?
Thanks
Old 07-08-2010, 05:26 PM
Restricted User
98Z28CobraKiller's Avatar
Holy ****! That's a killer deal. That's a complete short block assembled with a forged crank for $3600. Have you thought of selling a stroker kit (crank, pistons, rods, pins and rings)?
Old 07-08-2010, 07:16 PM
FrankSS's Avatar
what would yall charge for a long block fully assembled.. or just to have a cam degreed with the short block?
Old 07-08-2010, 11:39 PM
AES Racing's Avatar
Thanks
Compstar C-Series crankshaft is 5140 forged steel, nitrided journals, stronger then a factory crank. We've had them up to 800rwhp with power adder LS motor. I'm sure it has its limits, LS crankshaft dimensions are pretty stout, by comparison look at a 4.6 ford crank, its tiny.
You can run a 3.75" Callies magnum crankshaft, $1300 upgrade.
I wanted an engine design for the guy with single 88mm, twin 60mm, or D1SC, who can benefit from larger stroke, but need a HD piston.
Old 07-08-2010, 11:45 PM
AES Racing's Avatar
$175 to O ring block, $144 to machine receiver grove in heads.
Old 07-08-2010, 11:49 PM
AES Racing's Avatar
Yes, $1995 for balanced rotating assembly
C-series 3.825" crankshaft
Compstar H beam rods, ARP 2000 bolts
CP Pistons -15cc
NPR gas nitrided rings
King HP main bearings
King HP rod bearings
Fraser
Old 07-10-2010, 04:14 PM
AES Racing's Avatar
-GM MLS gaskets
Old 07-10-2010, 05:30 PM
Q8CamaRo's Avatar
cant wait to get my motor
Old 02-12-2011, 12:30 AM
GREG O.'s Avatar
Question 405 turbo build...
I have a callies c stroker making 405 ci. a 6.0 iron block +.005 over. Is an 88mm. or large turbo needed to satisfy the longer stroke...i saw u mentioned that in this thread...and what type of a/r housing and wastegate should be usedwas going to purchase an 88mm turbonetics t4flange with a 1.05 a/r...i don't know **** about all this but maybe AES or someone can chime in...thanks
ps: i know i am replying to a 7month old post but i did a SEARCH and this thread might help my turbo sale...
Quick Reply: AES Racing Engines FI Shortblock sale
