Crank pinning question...
I pinned my crank (horizontally - half moon in balancer/half moon in crank) when I did a cam install and ud pulley. Now thinking of a blower and will need to get rid of the ud pulley. My question is what is the best approach for re-pinning the new balancer. Assuming I used the stock balancer......once installed, the crank will have a half moon where I previously drilled and the balancer will not.......
nobody has had this issue/question before?
is it possible to align the pin kit with the half moon on the crank and sucessfully drill out the other half in the balancer so I keep the pin in the same spot on the crank. Or, repin 180 from where the crank is drilled now??
