F2 Procharger C6 setup is getting close...
Well there has been some debate on other forums that the F2 procharger will not fit or line up correctly with factory procharger brackets. Well it fits and fits great. Here some pics and as soon as I get the cog pulley for the head unit I can get a belt measurement. This particular setup is for a C5 or C6 Corvette. We will be ready for the Holley fest and the lsx shootout again this year as well
The motor is the same LSX427 that I had in the white T/A with the 94mm turbo.I had the motor completely refreshed and went with a larger solid roller camshaft this time around as well.(.670-.670 lift-.250.260dur@.50 on a 116lsa) The limiting factor of this setup is the tranny. The tranny is however the stage7 from FLT and I have full confidence in it at this power level. I will be limiting the power to appx.950rwhp. We should have it all installed by the end of next week. I will take some progress pics as we go.
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Been there done that in '07. You will want to read this thread to understand all the headaches we went through to get it to work. You will need to run the F2 on a dedicated belt, guaranteed. He has now since stepped down to an F1C. Good Luck!!
https://ls1tech.com/forums/forced-in...good-luck.html
The one HOB built has a 4l80e conversion I thought? If it only took 16psi, then I am golden. My motor has better heads and a bigger camshaft so it should breathea little eaasier than the one they built.I will be running a mixture of pump and race gas. Depends on what festiv activities are going on at the time.LOL
I think your right it was 4l80e
Well I had a little time today so I got the new motor and transmission and converter all swapped out. I also installed the new Cartek Flip Drive Kit as well.
I am going to run the setup N/A for a week or 2 and get the motor broken in while I await the intercooler setup to get here. Then I will install the F2r and let her eat.
The Tranny Is a FLT Stage 7 4l65/70e , the converter is a Circle D Billet,American Racing 2in. primary race headers.
Here are some more pics.
