another FMIC MP t70
another FMIC MP t70
So I had installed a set of stock ls6 heads and used the FMS f13 on a 112( i know, not the most ideal) and of course all the little things that go along with a cam/heads install. Dual springs..etc. My car is a 6 speed through a moser 9" with 3.89 gears. Originally was looking at this motor build with a 100 shot. But got a stupid deal on an almost complete turbo kit. Turbo is a MasterPower t70 with .96 a/r.
Running the car on 6lbs of boost. It made 533 hp and 494 tq. To say the least. I am happy.
space out that radiator hose so you don't unnecessarily heat up the air coming into the motor. doesn't make much sense to go thru the trouble of cooling down the air and then heat it back up with 200 degree water.
There are a few things i have still left to do. Will take the wrapping the radiator hose suggestion. Also plan on putting a blanket on the turbo. Going with a pc680 battery to make room for a filter. Also have to put a pusher fan on it as well. Sits just left of the 210 mark right now.
