after shutdown bearing lube
Is anyone running an accusump type deal to feed a BB turbo oil after shutdown since they spin for ever with no oil pressure? Will they flow oil through a restrictor on the turbo without the pump pushing on it? seems like easy insurance to maintain the turbo, just curious how well it works.
Idle down before shut off. We test this, even shutting down at 3000-4000-5000 and 6000rpms. As long as you idle down you will be fine...also allow the oil temps to come down if you have been driving hard. You don't want the oil to coke onto the shaft and piston ring area of the turbo.
I'm building a turbo setup for my car and am new to all the turbo stuff, so if you have to idle down before shutting the car off to keep oil to the turbo, how do you do plug checks to make sure the tune is right on all cylinders? As a nitrous car, I used to cut it immediately after going through the traps and get towed back and pull the plugs and make sure all the fuel rings and timing straps looked good. Is that only a ball bearing turbo that you have to let wind down before cutting the motor? Thanks for any help man!
