p1sc question
Old 08-05-2010, 11:33 PM
slolt1's Avatar
Default p1sc question
any body running a 6 rib 3.1 blower pulley with the factory crank pully from ati
if so how much boost you making?
Old 08-06-2010, 08:46 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Here's a bump for you. I'm curious too as to what people are seeing with this combination, but... See the info below.
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 08-06-2010, 09:24 AM
slolt1's Avatar
thanks bob i have several deferint pulleys with this and just want to see what would be the best set up
i have just about got this ready to go on
hopefully in a couple more weeks i can give you a call and get the rest of my stuff i need
Old 08-06-2010, 12:18 PM
30th t/a's Avatar
another bump, im curious as well
Old 08-06-2010, 12:59 PM
Packy's Avatar
When I first installed my P1SC kit I had a stock crank pulley on it and a 3.20 blower pulley was good for 8 psi, but it slipped really bad. About that time the MMS stuff was big. So after seeing a the dust build up everywhere I went with the MMS set-up and bigger pulley in 2003.
Old 08-06-2010, 01:25 PM
pdasterly's Avatar
I think you would be slipping at that point, on a 6 rib
Old 08-06-2010, 01:35 PM
Customizing Director
MadIceV8's Avatar
I would expect 9lbs. But a regular procharger pulley would probably slip. Maybe if you have it coated or a reichard racing pulley.
I'm attempting to get my 6-Rib to work as I just don't have the added fun money to invest in the SDCE setup.
Old 08-06-2010, 01:47 PM
Packy's Avatar
The SDCE is worth the initial investment. When you add up the cost of belts and pulleys to try and make the 6 rib work comes to under the price but to make good boost hassle free it is worth IMO. I still am running the MMS crank pulley with a 3.5" RR pulley. I am waiting until I upgrade to a F1A then I will do the SDCE.
Old 08-06-2010, 01:48 PM
30th t/a's Avatar
So I should forget about running 9-10psi on my 6 rib P1 setup?
It sounds like 7-8 is about the most you want to try and run on a 6 rib P1 setup.. true?
Old 08-06-2010, 02:11 PM
pdasterly's Avatar
I up to 12psi with mms crank pulley and 3.2 supercharger pulley, but i'm overspinning the p1sc 68,000, max is 62k i think.
Old 08-06-2010, 02:29 PM
30th t/a's Avatar
where is everyone getting these MMS pulleys? Do they make them anymore?
Old 08-06-2010, 02:42 PM
MadIceV8's Avatar
Nope. Otherwise I would have probably grabbed one. However SDCE might have a comparable one.
Old 08-06-2010, 02:45 PM
Packy's Avatar
The MMS crank pulley is 7.85" and the SDCE is 7.25"
You might as well buy the whole set-up though.
Quick Reply: p1sc question
