5.3l and 88 mm turbo? Pros and Cons Good or Bad?
That's really going to choke if we turn it up. I am just trying to not have to buy a turbo twice. Trying to get something for this little motor to get the car going and then something to work with an iron block 408.
I guess a little nitrous would help it off the line if I went with the bigger a/r
if and when you turn it up, change houseings. Im curious if it will spool under like 4k rpms, my 76 is a .96 and its going on a 346. What are your power goals with the 408? if its not over about 900whp you might go with like an st80 or t78
