How much to expect from a cam swap?
Old 08-10-2010, 12:02 PM
XtremeDime's Avatar
Default How much to expect from a cam swap?
Im currently running stock cam, and with 8psi I put down 485whp through a stock clutch(committed suicide on 3rd dyno pull). How much can I expect to gain from swapping to a Z06 cam or something bigger? Will the difference between the Z06 and like the EPP blower cam be nominal in terms of numbers?
Old 08-10-2010, 12:24 PM
LS1Tech Sponsor
hellbents10's Avatar
You will see about 510-520 with the LS6 cam at the same boost level.
Old 08-10-2010, 01:05 PM
yelo04goat's Avatar
didnt parish pick up almost 100 hp ???? or was that at a higher boost level???
Old 08-10-2010, 03:57 PM
99.9percenter's Avatar
Your stock clutch did NOT commit suicide...It was murdered.
Old 08-10-2010, 04:04 PM
XtremeDime's Avatar
We'll call it assisted suicide. lol
Old 08-10-2010, 07:12 PM
Gingervitis Addict
slow67's Avatar
Not at peak, the gain was lower in the power band.
Old 08-10-2010, 09:16 PM
9t8z28's Avatar
I have close to the same setup and I was told the EPP cam would net almost 60 rwhp. I'll now in a couple of months.
Old 08-10-2010, 11:19 PM
no1izspeshl's Avatar
With a non-boost cam (F13) and ls6 heads, I am making 533hp on 6lbs.
Old 08-11-2010, 04:39 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Let us know how it performs for you. We've had N/A cars pick up 60 rwhp with our cam, who can't yet afford to go forced induction, but are planning on doing so. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 08-11-2010, 07:53 AM
LS1Tech Sponsor
That was with a 5.3l and a 5.3l cam which is very small compared to even a ls1 cam.
Old 08-11-2010, 11:29 AM
XtremeDime's Avatar
If I pick up your cam Ill need to upgrade the valvesprings also, correct? What about lifters? Thanks
Old 08-11-2010, 11:41 AM
dschmittie1's Avatar
Well you can't run stock springs on the ls6 cam either. Lifter should be ok and just get some partiot springs.
Old 08-11-2010, 11:44 AM
9t8z28's Avatar
Will do
Old 08-11-2010, 12:04 PM
XtremeDime's Avatar
I already have ls6 yellows. I was just on Brute Speed's site reading about the cam and recommendations. I have a friend with some Patriot springs lying around, I suppose I could snag them. Id feel alot better if I picked up some ls7 lifters, they are only 150$.
Im pretty much sold on the Brute Force FI cam now. :p
Old 08-11-2010, 03:35 PM
Nitroused383's Avatar
That EPP / Brute speed cam suits centrifugal setups more than a turbo setup. I think you'd be much happier with a custom specced cam.
Old 08-11-2010, 04:25 PM
Restricted User
98Z28CobraKiller's Avatar
I wouldn't even consider running second hand springs. Springs fatigue and fail over time. Buy new ones. If you can't swing it right now, then sit tight until you can.
Old 08-13-2010, 01:06 AM
XtremeDime's Avatar
Anyone have an idea why the Brute Speed FI cam wouldnt be good for turbo?
Old 08-13-2010, 03:51 AM
That cam has a 50 degree intake valve closing event. In a naturally aspirated engine this would be a pretty high rpm cam, most good N/A cams for a 346 run between 39-48 degree IVC. This 50 degree IVC will have poor low end torque, which is what you want for a turbo. Great supercharger cam as superchargers have different airflow requirements with rpm. If you plan on running a 7000 rpm setup this may be a good cam but most guys with a 346 engine are running 22x/23x duration cams with a much lower intake centerline. 114 ICL seems pretty late, try something around 104-110 ICL would be much better for low end torque.
Quick Reply: How much to expect from a cam swap?
