My Precision 76mm turbo build
Old 08-11-2010, 12:49 AM
Greg@RET's Avatar
Default My Precision 76mm turbo build
Not too long ago I picked up a 97 Camaro and basically re stored it and turning it into a fun daily driver/track car. The real motor that is being built is a Alum. 402 with CNC heads and 9:1 compression. For now I am going to run this 347 with ported heads, cam, and 10:3 compression.
I have fabbed many turbo kits but for time constraints decided to work off the Ebay hot side kit. I was very hesitant but after seeing the stainless and the welds I am impressed. I did have to open up the flange holes on the header a bit and will be running the wastegate to atmosphere along with a 4" downpipe.
Some pics of the bolt in cage, currently out of the car getting powder coated the color of the car.
Some suspension shots..
Fuel system
Heres how I picked the car up lol
I will only have turbo pics for now on
Old 08-11-2010, 01:15 AM
TurboS10's Avatar
I like it!
97 & DBW????
Who makes the cage?
Old 08-11-2010, 01:28 AM
Greg@RET's Avatar
Originally Posted by TurboS10
I like it!
97 & DBW????
Who makes the cage?
I am getting the GM LS3 controller kit for the car. We made it here.
Old 08-11-2010, 01:47 AM
TurboS10's Avatar
nevermind....
Old 08-11-2010, 01:51 AM
BottleFedZ346's Avatar
I like the way you cut your bumper very different everything else looks great as well.....
G/l.....
Old 08-11-2010, 10:04 AM
GrannySShifting's Avatar
Id go a bit larger on the turbo for 400 inches
Old 08-11-2010, 06:13 PM
Greg@RET's Avatar
I agree, when that motor goes in we will see what the 76 does, I have a 81mm here on the shelf if we need it.
Old 08-13-2010, 01:11 AM
Greg@RET's Avatar
Modified the fans to fit the radiator..
V-band on the turbo, intercooler, and -20 fittings on the radiator.
Fuel lines routed for the return set up..
FP regulator mounted and lines running through the strut tower.
Old 08-13-2010, 02:28 AM
TurboS10's Avatar
Is that Fore FPR as pretty in real life?
Old 08-13-2010, 07:18 AM
cracker's Avatar
Yes. They are really nice units.
Old 08-13-2010, 10:52 PM
Greg@RET's Avatar
Yes it is, let me know if you need one. I think I have about 10 in stock
Heres a couple shots from today.
Had the cage picked up from the coaters..
Put on the water pump with the -20 fittings..
Also picked up something for the interior...
Old 08-13-2010, 11:04 PM
sixpack_2_go's Avatar
looks awsome man! i really like the color, looks very clean!
Old 08-13-2010, 11:20 PM
Wow looking sick man!
Old 08-16-2010, 10:16 PM
Greg@RET's Avatar
Put the cage back in...
Put the oil pan back on with the -10 oil drain on.
Old 08-17-2010, 11:18 PM
Greg@RET's Avatar
Only thing I was able to do today... bolt on the new valve covers with the -10 breather fittings.
Old 08-18-2010, 05:44 AM
White.Lightning's Avatar
Nice build. Keep up the good work
Old 08-18-2010, 08:48 PM
Greg@RET's Avatar
Thanks man
Well the inside looks like a car again, other then the wire nest out of the cluster lol
Decided to mount the coils down in the fender (car will never be driven in the rain).
Put some stuff on so wires wont burn up.
Put the oil drain on.
Old 08-18-2010, 11:16 PM
Datankid069's Avatar
Where can I get just the hot pipes that you have without all the extra ****?
Old 08-18-2010, 11:29 PM
XtremeDime's Avatar
The ebay hotside is on ebay?
I dont know what you mean by "all the extra ****"
Old 08-19-2010, 12:16 AM
eviltwin_1987's Avatar
Is it just me or is that drain at like a 45* angle
Quick Reply: My Precision 76mm turbo build
