Building Boost w/ 2 Step In A 6SPD Car
Old 08-12-2010, 08:56 AM
KnightmareLS1's Avatar
Default Building Boost w/ 2 Step In A 6SPD Car
Just wondering if any of you guys have the LNC-003 2 -step? I just put mine on not too long ago an even with it set at 5k I could only get about 2-3lbs. I would hold the pedal down for 5 seconds and it never went higher. Was wondering if maybe the 002 with timing retard would help a lot more? Anybody have exp. with the 003 and not playing with the timing? I would like to get full boost(7-8 lbs) on the line. All input is appreciated
Old 08-12-2010, 09:33 AM
Gabbiani's Avatar
Manual needs major timing retard to build boost on the line or 2 step. Like atdc if possible.
Autos get load from their setup and actually need more timing to build boost on the line.
Old 08-13-2010, 01:25 AM
yessir's Avatar
major meaning??
Old 08-13-2010, 02:02 AM
Nitroused383's Avatar
He said after top dead center. That would mean negative timing. You can go down to -25 degrees with hptuners if you set the min retard to -25. I believe what you are doing is trying to ignite the mixture more in the exhaust to spool the turbo. I imagine it creates crazy high egt but that's not the piston crown temp.
