What are the correct valves (LS3 head) for FI
Old 08-15-2010, 02:29 PM
Philly-Goat's Avatar
Default What are the correct valves (LS3 head) for FI
Quick question: Will the stock LS3 valves be okay to run FI, or should I change them out for stainless steel? Thanks for your input!
Philly-Goat
Old 08-16-2010, 09:29 AM
camarols1's Avatar
Keep in mind that any hollow stem valve is not going to be as strong as a premium one piece valve.
That being said, if this is a mild build with a quality beehive spring you will be ok, but for a max effort build with heavy dual springs I would advise upgrading to a solid valve for durability.
Just my $.02
Quick Reply: What are the correct valves (LS3 head) for FI
