Best Map for 18+lbs
Old 08-15-2010, 09:35 PM
FasTimeSS's Avatar
Default Best Map for 18+lbs
I know i will need a new map sensor but will i need a 2 bar or 3 bar if im running 18lbs or more?
Old 08-15-2010, 09:40 PM
Coal Mining Director
onfire's Avatar
GM 3bar.
Old 08-15-2010, 10:01 PM
FasTimeSS's Avatar
part number?
Old 08-15-2010, 10:06 PM
FasTimeSS's Avatar
i found this one
http://www.gmpartsdirect.com/results.cfm
part number 12223861
but what do i do for the old plug? it says u need a new one?
any one done this before?
Old 08-15-2010, 10:42 PM
BigRich954RR's Avatar
they make 2.5 bar which i think im running and its plenty for what your doing i think it good to 21.5 psi
Old 08-15-2010, 11:31 PM
FasTimeSS's Avatar
no i def need a 3 bar because ill be runnin around 23 on race gas.
Old 08-16-2010, 08:09 PM
FasTimeSS's Avatar
no one knws what to do for wiring on the gm 3 bar one?
Old 08-16-2010, 08:16 PM
onfire's Avatar
Go to the Speed Inc site. They carry the 3 bar map and the wiring pigtail to plug it into the factory harness.
Old 08-16-2010, 09:08 PM
Restricted User
Zero4488's Avatar
You cut and rewire it.....if you go with the FAST 3 Bar they give you a male plug that you have to pin. You can get the pins at radio shack....or just get the FAST adapter harness....which ever works....just one costs more....
-Dave
Old 08-16-2010, 10:43 PM
FasTimeSS's Avatar
awesome thanks guys
Old 08-16-2010, 11:23 PM
Pocket's Avatar
Just use a small paper clip to depin the stock MAP connector and transfer them to the new connector body. No cutting needed
Quick Reply: Best Map for 18+lbs
