Process of Mounting Intercooler
I have a 31x12x4 intercooler on the way and i started pullin off the front assembly and i would just like to see how most of you guys are mounting them into the front portion of the car, all i can see about doing it is cuttin up the front support to modify the two bolts to come down and attach to the intercooler, does anyone have some detailed pics of something similar done?!
btw i tried searching and didnt have much luck
It's a custom fab and most guys use different sized FMICs so one mans setup wont always work for you
Best bet is to disassemble the front of the car and hold the IC in the position you want it to be in the end. Then fit, build brackets, reassemble the body and plumb. Same process would apply to any vehicle
Heres my 3rd gen with a 31x12x3 FMIC
Fitting infront of rad
Fabbing brackets
Plumbing
Fabbing brackets
Plumbing
Fabbing brackets
Plumbing
Fabbing brackets
Plumbing
please explain your build
No help? What are you expecting us to come do it for you? I told you the process, you've seen pics. Just do it. You're fabbing a custom setup, youll have to figure out small problems like fitment and such. Sometimes a notch is required, sometimes stuff has to get moved. YOU have to figure it out
Nope i actually just unbolted the crash bar up front drilled 2 holes into the plastic thing and bolted it in it seems to be ok for now but i still gotta make some mounts to secure it to the bottom.....
