Stock 6.0 chevy twin turbos
I bought a 6.0 escalade motor thats has 35,000 miles and wanted to add twin turbos for my 70 chevelle but the problem is that im keep hearing all these different things i want to buy the pro flow intake and maybe change the cam and wanted to buy the turbos off ebay but ive been hearing on here not to buy the china turbos need some help with the run down on how i should set this motor up ive lost alot of sleep trying to look this up thanks for the help guys!
well, if you want budget turbos, master power can't be beat . if your looking at ebay/china turbos, you probably want to look at a few of the z06 cam/ls6 intake manifold builds, budget minded and proven to go 9s in 3700 lb cars. Im moving over to a 6.0 my self
If you have the room for the Pro Flow, I say use it. One of the local turbo shops here in Phoenix can build a couple 57mm T4 Garrett turbos that flow 50lb each for around $850 for both. Pm me if you want the info. For that stock motor I would put good rod bolts in it and head studs.
what year 6.0?.. deff do not get ebay turbos..heard stories to.. mastor power has good turbos,, used one my self.. most poeple swap a ls6 cam in them.. i did in 5.3,, now upgraded to a ly6 6.0 l92 heads factory,, im bout to install ls3 cam,just bout same specs as ls6.. and a single turbo..good luck on your build..make a build thread.. with lots of pics.
I have a stock LQ9 (with just LS6 cam), pro-flow intake, and 2 stock GN turbos in my 70 Chevelle.
Stay away from the ebay/china turbos.
Can't really give a turbo recommendation without knowing your power goals.
Info
