Gear ratio recommendation!
Getting ready to order a ford 9" and need help choosing a gear ratio. Currently running 3.42s. Right now Im trapping 121 and Im at about 4-4.5k when I cross using stock size tires. Thanks guys
Really? That short? I figured 3.7x maximum. I even thought about going with something a little taller, that way there would be more time in boost in between the 3-4 shift.
Im an m6, in case anyone didnt know. lol
3.73 or 4.10 gears would be ideal now, but you could be on the limiter in 4th before the end of the track with another 150+ hp.
Maybe keep the rear for now, and do some easy passes with the new setup to see what the rpm's are going to be through the traps.
I made the mistake of going to 3.73's with my old sbc/procharger combo, but my current setup will likely make that 3.73 more ideal for 1/8 mile, LOL...
The rear is the only thing holding me back from 11s as is. I would imagine 600whp is a pretty good estimate, and I wont be going crazy with the cam since I wont spin it above 6500.
