wastegate quastion
wastegate quastion
i am having a couple of issues with my boost controller, it seems like it does not let one of the wastegates close
if i just remove the two vacuum lines of each wategate, they will just run of the 6 psi spring that is inside of them ? or will i need to connect both of the ports together on each gate ?
