Installing ATI balancer 918853
So I have the ATI balancer 918853 pre-drilled for the procharger pulley. Question: do the 3 longer bolts that go throught he supercharger pulley also extend into the a/c pulley? My a/c pulley has 3 holes big enough for the bolts and 3 that are the smaller size for the flat top countersunk screws, but those are not long enough to go into the other 3 a/c pulley holes and the offset is wrong. And if I put the 3 other bolts into the balancer/hub they are too long to not hit the a/c pulley. I read the ATI instructions but they are crap. Any help?
So you had the 3 bolts going through the supercharger pulley also going into the a/c pulley. Did the other 3 bolts that hold the damper to the hub (not the 6 flat top screw) go into the a/c pulley or not? The sizes dont fit on mine
918853, ac, ati, ati918853, balancer, damper, install, installation, installing, instructions, ls1, ls2, performance, pulley, putting
