Turbo 370 guys...how high are you revving?
Old 09-05-2010, 05:37 PM
Mike454SS's Avatar
Default Turbo 370 guys...how high are you revving?
Looking for some feedback from anyone running a turbo on a 370...how high are you revving? If you're willing to share any details on your engine setup, please do.
Old 09-05-2010, 05:39 PM
JAX04's Avatar
In for details, lol. was thinking about this in the shower today LMFAO!!
Old 09-05-2010, 05:40 PM
99Ls1fever's Avatar
The 370, we just built at the shop with a s80 we are rapping 7500
Old 09-05-2010, 05:48 PM
MUSTANGBRKR02's Avatar
I don't know mine won't go over 5500
Old 09-05-2010, 08:41 PM
Gonoma's Avatar
how high you can rev it is gonna have a lot to do with your valve train though right? or what your rev limiter is in your pcm
Old 09-05-2010, 09:09 PM
So.jerZ-28's Avatar
with hydraulic lifters I wouldn't go above 7200-7400
if you want to pul higher than that I suggest solids w/suffecient springs to boot!!!
Old 09-05-2010, 10:53 PM
KrisXpc's Avatar
My friend made Max power at like 5800 I think and then started to drop after that. He is a forged 370 with APS twins, with patriot Stg II 5.3 heads and a mild custom grind cam. Maybe he needs better heads? Wrapping to 7500 is kinda rediculous.
Old 09-05-2010, 10:56 PM
Mike454SS's Avatar
My goal is a 6500 RPM shift point, and I'll probably set the rev limiter at 6700-6800...everything I'm putting in the bottom end can take a lot more (forged crank/rods/pistons and billet mains with really nice fasteners holding it all together...and I'm planning on a nice stable valvetrain as well...but it's a build for a street car, and I don't really want to be revving it much higher...I think I can cam it to make the power I want in that range...I hope.
Old 09-05-2010, 11:23 PM
Syclone354's Avatar
I have my shift points set at 6700 1st to 2nd 6800 2nd to 3rd iirc. It pulls straight to the shift, but i really dont need to rev it any higher. Its a 370" lq9 eagle rods weisco pistons balanced all arp in bottom. Up top is 317 heads comp valvetrain with a crappy z28 ls1 intake and truck throttle body. turbo is a .96 ar turbonetics 76 bb...
Old 09-06-2010, 01:49 AM
Zombie's Avatar
7k is as high as I ever take mine, but I think I'm over revving it, just taking it there due to gearing.
Old 09-06-2010, 08:02 AM
Fireball's Avatar
about 8000
Old 09-06-2010, 08:05 AM
Restricted User
transammiller's Avatar
i shift mine at about 6100. thats where is peaks out at.
Old 09-06-2010, 08:31 AM
JAX04's Avatar
good info, its clear that the guys who drag their cars competivley wrap theirs much much higher.
i personally couldnt see myself revving past 6500 on the street. we shall see.
Old 09-06-2010, 12:35 PM
Zombie's Avatar
That's as high as I'll usually go on the street. That's also around 120mph in 2nd for me lol.
Old 09-06-2010, 07:10 PM
bad6as's Avatar
a few hundred after the cam peaks
Old 09-06-2010, 09:04 PM
Sluggish's Avatar
7k rev limiter, usually shift at 6800
Old 09-07-2010, 10:11 AM
Mike454SS's Avatar
Did a little more math last night (hope I didn't screw it up like I did the other day when I was tired), and it looks like I want to change to a 3.90 gear and have a limiter right in the 7000-7100 RPM range.
Old 09-08-2010, 05:19 AM
9 Second Truck Club
stock48's Avatar
I shift at 5600RPM with the TC76/.96, hit the traps at 6200RPM@129MPH. With the PT88, I shift at 6200RPM, hit traps at 7000RPM@143MPH clipping the limiter. This is a 4850LB 4x4 truck.,3.73 gear, 28" tire 80E unlocked.
Old 09-08-2010, 04:43 PM
Mike454SS's Avatar
Thats the best reply I've seen yet...I'm very excited to see the numbers you put up...my car will weigh in a little (but barely) lighter than your truck.
How much is done to your 80E? Do you use any torque management in your tune?
Old 09-09-2010, 12:46 AM
9 Second Truck Club
stock48's Avatar
Wow that's a lotta car! What is it? Stock 80E with a Transgo HD-2 shift kit. It has lasted me 3 yrs, but is about done I think. No matter what I do I can't keep it off the limiter on the 1-2 shift on high boost. No tq managment, just wore out tires lol.
Quick Reply: Turbo 370 guys...how high are you revving?
