Procharger now running HOT
Old 09-06-2010, 04:39 PM
LSXFORMULA99's Avatar
Default Procharger now running HOT
after the procharger install my car runs hot in town. put a new water pump and stat on and still same thing.
can sit in driveway and run forever and not over heat. as soon as i take it out it starts creeping hotter and hotter. on the highway it seems to be fine but as soon as i get off the highway its running hot.
if i turn the heat on it usually keeps it under control a littler better.
Old 09-06-2010, 05:04 PM
bpope's Avatar
Are you running the fan shroud supplied from the kit - the one that blocks off half of the radiator? If so...that is more than likely the problem.
Old 09-06-2010, 05:31 PM
hatcher1986's Avatar
are u running the fmic or the twin intercooler setup?
Old 09-07-2010, 05:34 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
I'll bet the fan is running the wrong direction, it is very easy to wire the fan to where it is pushing air into the radiator instead of drawing air from the radiator. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 09-08-2010, 07:40 PM
i can feel the fan blowing towards to engine so i dont think its that. i have the twin intercooler.
Useing the fan thats supplied in the kit.
Old 09-08-2010, 11:26 PM
sixpack_2_go's Avatar
talk to bob at brute speed he sells a small spal fan that you can fit beside the fan that was supplied with the kit.
Old 09-09-2010, 12:02 AM
white01ss's Avatar
sd-concepts also sells a compete shroud and dual spal fan kit that works great.
Old 09-09-2010, 12:51 AM
i didn't see it on the sd-concepts website. do you have a link to where it can be bought?
Old 09-09-2010, 06:35 AM
LS1Tech Sponsor
Make sure the ProCharger fan is not blowing at the radiator and bouncing off, to give you the illusion that the fan is spinning the correct direction. It is very easy to wire it incorrectly. Bob
__________________
Old 09-09-2010, 01:03 PM
white01ss's Avatar
They do much more than what's on their web-site so you probably have give them a call. Wendy is great to deal with.
Old 09-09-2010, 02:42 PM
ok thanks
Old 09-09-2010, 09:14 PM
Ryan33187's Avatar
If you smoke or anything just put a cig up to it and watch if the smoke pulles into the fan or away from it... I did this under the car in the area between the fan shroud and the engine.
Old 09-10-2010, 04:15 PM
white01ss's Avatar
Or stick a piece of cardboard in front of the radiator. If it stays put then the direction good.
Old 09-11-2010, 05:57 PM
cals400ex's Avatar
i bought the sd fan shroud. it is $400. i have not used it yet so i do not want to comment on how well it works.
Quick Reply: Procharger now running HOT
