Guess my backpressure - Results tonight.
Old 09-08-2010, 09:26 AM
czwalga00gt's Avatar
Default Guess my backpressure - Results tonight.
Just for fun, who wants to guess my backpressure. I'll be testing it tonight.
My dyno flatlines at 4500 rpms at around 550rwhp. I thought I bought at turbo with a .96 housing. Later I found out that my housing was .81
Parts:
Built LS2
Ported Heads
Turbo Cam
T76 @ 15 psi
.81 Housing
Front mount
I'm going with 51 psi.
Old 09-08-2010, 10:48 AM
qqwqeqwrqwqtq's Avatar
I'll go with 44psi
Old 09-08-2010, 12:05 PM
TracyRR's Avatar
I say 48#.... Good luck
Old 09-08-2010, 12:22 PM
SincalT/A's Avatar
What size is the wastegate?
Where in the system you gonna measure from?
Old 09-08-2010, 01:12 PM
I have two 38mm wastegates. It's measured in the one bank about a foot from the header collector. I have an extra o2 bung there.
Old 09-08-2010, 03:35 PM
Welp, you guys were close I overshot. 43 psi.
I only ran out 2nd gear though, not sure if it would be more in 3rd/4th with a longer sustained load. Wonder how much power i'm losing because of it.
Old 09-08-2010, 03:56 PM
7 Second Club
Phil99vette's Avatar
So at 15psi your seeing 43psi of backpressure? *****! 1:1 is awesome, 2:1 is good, 3:1 is a power robber
Old 09-08-2010, 04:25 PM
Yep, well after the dyno i did more research and my turbo wasn't what I thought it was. After I found the .81 AR ratio I had a good feeling it was my problem.
Old 09-08-2010, 04:57 PM
7 Second Club
Whats behind the .81, dual or single wastegates, dumped to the atmosphere? What size downpipe?
Old 09-08-2010, 05:03 PM
Duals dumped to atmostphere, 3" DP for about 3 feet then it goes to 3.5"
Old 09-08-2010, 09:00 PM
Tiago's Avatar
you need bigger than a 0.96 I would say 1.08 would be a nice compromise...
Old 09-08-2010, 09:52 PM
LS1TECH Sponsor
DrTurbo's Avatar
Parts:
Built LS2
Ported Heads
Turbo Cam
T76 @ 15 psi
.81 Housing
Front mount
What turbine wheel???
Old 09-09-2010, 06:31 AM
F1-68? I think. Can you maybe PM me with what I need to buy. I was going to email you guys here in a little after I figure that out.
Definatly looking for a 1.08/1.15 ratio depending on what is available.
Heres my description for the turbo I have:
60SE-SB-H76-D-D-68-OCO_81
Old 09-09-2010, 08:12 AM
mike13's Avatar
That sounds familiar, my motor did the same thing with a .96a/r on a TC76, I ended up stepping up to a ST80
383 (stroked ls)
ported heads, cam
Old 09-09-2010, 10:57 AM
LS1TECH Sponsor
DrTurbo's Avatar
ST80 will do it, also you can go with some other units. Just give us a shout....we can narrow the choices down.
Old 09-09-2010, 01:43 PM
I'm not looking for another turbo... just a housing. I dont have any room to add anything bigger. The turbo sits millimeters away from the crank and radiator.
I'm leaving for vegas tonight, so let me know what you think and ill get back to you next week.
Old 09-10-2010, 01:08 AM
350SS's Avatar
Are you using a mecahnical or electrical gauge to measure? Datalogging or just watching the gauge?
Old 09-10-2010, 09:19 AM
Gabbiani's Avatar
Space is limited but that 3" isn't helping either. I think my mp70 was more like 4:1.
Old 09-10-2010, 10:22 AM
LS1TECH Sponsor
DrTurbo's Avatar
The MP units will be well into the 4:1 ratios as the turbine wheels in their 70 and their 76 flow much less.
Old 09-10-2010, 10:23 AM
LS1TECH Sponsor
DrTurbo's Avatar
Ok...just let us know.
Quick Reply: Guess my backpressure - Results tonight.
