Need advice for oil lines
I have the Moroso conversion pan for my 67 firebird bolted up with twin -10an fittings for my Moroso oil relocation kit that has an in and out port, both that are 1/2NPT. On the top I've also got a 1/2NPT port that I'd like to tee off for my 1/8NPT oil pressure sensor (aftermarket gauge) and -4an for the oil feed with a .060" restrictor. The top port in the relocation kit is female 1/2NPT. Any advice? I don't have a spot like I did on my TA that I can tap above the filter. Already have the drain setup drawn out, just have an issue on filtered, pressurized oil to my gauge and turbo.
