opinions on what head gaskets to use with 0-ringed block
Old 09-15-2010, 12:35 AM
lifted99GMC's Avatar
Default opinions on what head gaskets to use with 0-ringed block
the car has a 6.0L iron block and is currently running an externally leaking set of SCE copper gaskets. I pull the heads to replace with a set of cometic MLS gaskets and see that the block has been o-ringed, but no receiver groove on the AFR heads. I have heard people o-ringing the heads with MLS gaskets and having good luck, but not so much the o-ringing the block with MLS gaskets.
What would be the best option BESIDES the SCE? will the cometics work well with the O-ring? It will be a higher boost engine, with 8-900 RWHP.
what about smashing down, or removing the o-rings in the block and running a LS7 cometic so the compressed ring on the gasket will be sealing in a different location?
My machinist suggested the best route to go would be to pull and disassemble the engine, smash down the o ring into the block, and deck the block to make it all flat again...then go with MLS gaskets.
Thanks for your suggestions.
Old 09-15-2010, 06:22 AM
Sluggish's Avatar
Why not have a receiver ring cut into the heads? This is a good question, I am thinking about pulling my motor to have it o-ringed.
Old 09-17-2010, 02:48 PM
cjg454ss's Avatar
i run the ls9 gaskets with l92 heads. oring in thhe block. 1000rwhp, no sweat
Old 09-18-2010, 10:24 AM
1320's Avatar
This is good, but how bout being specific?
groove size? groove depth? stainless wire? copper wire? wire diameter?
stock gasket?
Old 10-06-2010, 07:05 AM
cjg454ss's Avatar
stainless wire, just throw the ls9 gaskets on there, torque it down. it will cut and seat just fine.
Quick Reply: opinions on what head gaskets to use with 0-ringed block
