346ci t76 lq9 317 heads but what cam ?
Old 09-15-2010, 02:31 PM
sayed_000's Avatar
Exclamation 346ci t76 lq9 317 heads but what cam ?
my friend is building his first Turbo camaro ..
mods:
T76
5.3l manifolds
stock 346ci ls1 with 60kMI
stock 317 heads
.51 comic head gaskets
212 / 218 .522 / .529 114 LSA
high milling oil pump
ls6 intake
stock ported TB
ngk66
msd wires
48 injectors
9PSI
and he's wondering if his current cam will work well with his build?
any other things he's missing ? what cam should he go with ? 224R maybe?
Old 09-15-2010, 03:01 PM
1998TA__1991RS's Avatar
Zo6...
Old 09-15-2010, 03:50 PM
ReApEr75's Avatar
X2 on Z06. You can also get a custom grind turbo cam. Also those 48lb injectors might work. But if you plan on turning the boost up you might want to get 60lb
Old 09-15-2010, 06:06 PM
HydroStream6's Avatar
If he doesn't feel like changing it, it should work well on a turbo car. The 02+ Z06 cams do work well on a budget as well, and it's what I run.
Old 09-15-2010, 06:08 PM
BottleFedZ346's Avatar
X3 for a Z06 cam which i am running also.....
Old 09-16-2010, 11:35 AM
sayed_000's Avatar
how about using 48 comics instead of 51 ? to rise compression little ?
Old 01-29-2013, 08:25 PM
JoshuaGrooms83's Avatar
i iknow im diggin a bit but im doign somthing simular and was wondering how that project went
Quick Reply: 346ci t76 lq9 317 heads but what cam ?
