procharger mounting questions
Old 09-17-2010, 01:50 PM
98blackbirdta's Avatar
Default procharger mounting questions
Has anyone mounted a PC blower on top in a 4th gen??? i plan on geting one here soon (i hope). i have a few ideas of how to do it but i want to see if anyone has done it. and how theyre set-ups look
thanx
Old 09-18-2010, 06:10 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
About the only way I see it working is with the ProCharger Corvette bracket. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 09-18-2010, 02:59 PM
NemeSS's Avatar
will the blower assembled using the corvette bracket cause any interference in a 4th gen?
which head unit model?
Old 09-18-2010, 05:48 PM
i was thinking the corvette bracket would work but it seems like the blower would hit the shock tower??? it doesn't extend out far enough???
Old 09-18-2010, 07:25 PM
Another way I was thinking is using the gen 5 cama braket, it bolts over the factory power steering and may stick out far enough to clear the shock tower but the blower may hit the radiator and ill probably need to move the brake lines, this would be easier if I actually had a blower
Old 09-18-2010, 09:48 PM
9sectruck's Avatar
i have been looking into building a bracket to mount on passenger head the only thing is you have to relocate if not remove the ac canister, I made my own brackets to mount a f1 on my gto on the stock belt drive line in stead of using a separate drive like the stander kit
Old 09-19-2010, 07:52 AM
joeys99z28ss's Avatar
good luck and lets see some pics when you figure it out
Old 09-19-2010, 09:01 AM
LS1Tech Sponsor
Question
I'm not really sure but I don't see it hitting. The Corvette bracket works real well in 3rd gen RX7's with LS1 transplants. Bob
__________________
Old 09-19-2010, 09:10 AM
helicoil's Avatar
Yeah, and with the Cartek flip drive can't you run a F1R successfully?
Old 09-19-2010, 09:44 AM
LS1Tech Sponsor
Yes you can, the first time we used one at the old shop we had the belt adjusted tight the way we always have had to have them, and on the first run on the dyno we let out of the gas the the belt snapped in two! After that we kept belt tension looser and didn't have any slippage problems. You can also go cog with the Flip Drive too, so you could run an F2 without any problems. Bob
__________________
Old 09-19-2010, 12:04 PM
Sweet so I should be safe with an f-1 blower??
Old 09-19-2010, 01:33 PM
helicoil's Avatar
Would that have been a 10 rib belt with the F1R?
Old 09-19-2010, 08:33 PM
LS1Tech Sponsor
I don't see why not. Bob
__________________
Old 09-19-2010, 08:34 PM
LS1Tech Sponsor
http://www.exoticperformanceplus.com...Car.php?car=51
8 rib. Bob
__________________
Old 09-19-2010, 11:34 PM
So with that flip drive system I wouldn't need to convert to vette accessories????
Old 09-20-2010, 06:08 AM
LS1Tech Sponsor
No, you still have to have the Corvette accessories. Bob
__________________
Old 09-29-2010, 02:01 PM
wforty94's Avatar
so... does the corvette bracket and procharger deal fit on an f-body?
Old 09-30-2010, 06:41 AM
LS1Tech Sponsor
I have never tried it, but you would have to convert the engine over to the Corvette accessories and the inlet routing over the top of the radiator may create some necessary modifications. Hopefully someone has done it and will chime in, with the Cartec Flip Drive this would be a great way to go to run an F-1R or F-2. Bob
__________________
Quick Reply: procharger mounting questions
