what size pulley to max out d1sc on forged 347
Old 09-17-2010, 10:08 PM
pdasterly's Avatar
Default what size pulley to max out d1sc on forged 347
p1sc setup maxed out at 550rwhp@5500 rpms at 12psi(belt slip 6 rib). what combo will max out a d1sc? also will this setup get me to 750-800 rwhp.
Old 09-17-2010, 11:01 PM
conan's Avatar
Are you planing on upgrading to a 8 rib set up ?
Old 09-17-2010, 11:39 PM
pdasterly's Avatar
i have the ati balancer with stock procharger crank pulley and 3.4 supercharger pulley,
8-rib
Old 09-18-2010, 12:49 AM
Nitroused383's Avatar
(crank pulley size / blower pulley size) * (step up ratio) * (RPM) = Blower RPM
(7.25 / 3.4) * 4.1 (for d1sc) * 6000 rpm = 52,000 rpm
7000 rpm with the same size pulleys = 61,200 rpm
Max D1SC RPM 62,000
Old 09-18-2010, 10:02 AM
pdasterly's Avatar
so its maxed out? i guess my next question is how can I increase boost inside the motor(what heads do I need)? Do I want to increase or decrease backpressure and how?
Old 09-18-2010, 10:58 AM
fatmat80's Avatar
Yes you can make 700+ with a d1sc.
but you will need a stout combo.. I would say a good recipe would be:
afr 225 or tfs 215s or ported 243s/317s
ls6 or fast 102 intake
blower cam(bob makes a good one)
large filter if you are running twin coolers.
meth
1 7/8 headers
no cats
at least a 3 in exhaust or true duals
fuel system
great tune!!!
There have been a lot of guys to do it but its not easy..goodluck
Old 09-18-2010, 01:21 PM
pdasterly's Avatar
motor is forged, 9.1 compression ration(eagle rods, mahle dished pistons(20psi max), stock crank). ported 243's(corvette) and professional products intake and cheap ebay throttle body. ls9 cam. I dont run a filter on the dyno. Headers are obx longtube 1 3/4(flp knock-offs) no cats, off-road y-pipe, factory exhaust with mangnaflow muffler. Fuel system has two walbro in-tank pumps, 80lb injectors, professional products fuel rails, aeromotive fuel pressure regulator with new return to tank. Here's my previous dyno(video in signature), detuned slightly, maxed out at 548rwhp 510rwtq @ 5500 rpms at 12psi with a p1sc(MMS crank pulley and 3.2 procharger pulley). we couldn't get car to spin to 6800 rpms due to belt slip but that was with the 6 rib stuff.
Old 09-18-2010, 01:33 PM
pdasterly's Avatar
I Live in California 91 Octane Only
Old 09-18-2010, 02:19 PM
conan's Avatar
Do you know the size of your crank pully? Some people have used a 3.1 blower pully depending on the crank pully size. Also you might want to look in to a meth kit. When I ordered my snow kit, the sales rep told me that a 50/50 meth/water with the 91 octane I get in utah will be in the 108 - 110 octane range.
Old 09-18-2010, 02:30 PM
pdasterly's Avatar
stock 8 rib procharger pulley.
Old 09-18-2010, 03:44 PM
blue00ZZleeper's Avatar
Theres guys making 750+ rwhp with a 347 and a D1. AFASTYZFR1 made 764 IIRC with the blower hat off on his 347 setup. There are guys making decent power, but a good setup is important as fatman80 said. I would look at methanol as well. Where in CA do you live? You'll need bigger headders and lose the PP intake. I picked up over 30rwhp going from the PP manifold to the LS6. It got reeal hot and kept IAT's a little higher. When I switched we could add a little more timing without detonation. What size is the MMS crank pulley? I would also look into getting a aster bracket if you want to max it out, the lower the belt slip the more efficient the combo the more power you'll make
Old 09-19-2010, 04:26 PM
The professional products intakes are known not seal worth a ****. My friend had one on his procharged GTO and we had nothing but problems with that POS.
Old 09-19-2010, 04:38 PM
Aster's Avatar
The stock Procharger 8 rib crank pulley is 7.625" in diameter. A 3.4" head unit pulley will max it out. That said I know a guy in New York with one of my brackets, and a meth kit using a 3.7" head unit pulley and a comparitively baby cam put down almost 750 rwhp with a forged 347.
Old 09-19-2010, 08:31 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
http://www.exoticperformanceplus.com...Car.php?car=54
We made 740 rwhp with a Mustang Chassis Dyno with stock cubes, baby cam and a D-1SC with the above Corvette at the old shop. I agree on getting rid of the Chinese intake manifold, I'd just put an LS6 intake on there. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Quick Reply: what size pulley to max out d1sc on forged 347
