What size pulley ???
i have ProCharger F1R head units i want to know What size pulley are i using to get 20 psi?
my crank pulley size 7.65"
my engine 383 cid
thanks
navy
my engine 383 cid
thanks
navy
no one knows how to respond to my question f.....k
where the Engineer in this site ?
where the racer ?
Did my question in this difficulty ?????
loooool
where the racer ?
loooool
LS1Tech Sponsor
Hi Navy, I got your pm. Tell Jassim I said "Hi", I haven't talked to him in quite a while.
You're probably going to need a pulley in the 4.25 range, but there are many variables that affect how much boost you'll see. Bob
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
You're welcome! Bob
__________________
