Water Vapor Collection system
Old 09-20-2010, 01:36 PM
XtremeDime's Avatar
Default Water Vapor Collection system
Theres been a couple threads on here concerning stock vapor or steam vent setup and how it can be improved. I know Kurt Urban sells a very nice setup but its hard to merit 200$ for most people. Im thinking about picking up a 4port vacuum block like this:
Then tapping 4 of the block off plates or picking up the ones Kurt sells for 10$ a piece, and tapping them. Then running them to this vac block, positioned vertically. Then run a hose from top of the vac block to the radiator.
It wont be as nice looking at Kurt's since I wont be using steel braided lines but this should work, in theory.
Old 09-22-2010, 02:30 AM
Restricted User
transammiller's Avatar
I run a similar setup. i just tapped my heads with 1/16" NPT threads and used -4 fittings on all four corners. then ran all four to a Nitrous Outlet distrobution block. then from there to a -4 fitting located in the top of the water pump. it has been working great so far and i havent had any problems with it.
Old 09-22-2010, 07:26 AM
Julio's Avatar
I guess the idea is to purge possible air out of the coolant system?
Old 09-23-2010, 07:22 AM
stevieturbo's Avatar
it doesnt need to be mounted vertically.
But putting the outlet into the top of the radiator is stupid, unless the radiator has some way of venting air.
if it doesnt, all that will happen is you'll create an air space in the radiator, causing a massive drop in cooling ability.
It MUST go to the air void within the header/expansion tank. Just look at any OE cooling system. They all vent to that location.
Old 09-23-2010, 12:14 PM
427's Avatar
That should work well, and if the engine is apart you can tap the bleed holes in the head and get away with not using the adapter for cost savings. Keep the lines running uphill if possible and the single outlet that bleeds the highest point in the collection system and the air will be forced out!
Looks like a nice solution!
Kurt
Old 09-23-2010, 12:23 PM
XtremeDime's Avatar
The OE cooling system has it going to the top of the radiator.
427's Avatar
The return is most common in the top of the radiator on the suction side. If you are street driving it, the common recovery type system used on production cars in the 80's and 90's will clear the air out of the radiator although most race type cars use a open "puke tank" type system and this also works well.
Kurt
Old 09-23-2010, 12:34 PM
7 Second Club
Phil99vette's Avatar
Looks like a nice solution but I'd rather spend the extra money and not fight with the barb'd fittings on removal.
Old 09-23-2010, 12:57 PM
XtremeDime's Avatar
Haha no ****, but Im cheap so Ill give it a go.
Old 09-23-2010, 01:08 PM
7 Second Club
One day you will not want to be cheap anymore.
Old 09-23-2010, 01:15 PM
XtremeDime's Avatar
One day.
Old 09-23-2010, 02:16 PM
427's Avatar
I don't want to be cheap now, but it's all I can afford!!
Kurt
Old 09-23-2010, 08:15 PM
trans2000am's Avatar
Kurt
Kurt,
Do you have 1 of your kits in stock? If so I'll come pick one up tomorrow
thanks
ryan
Old 09-23-2010, 09:02 PM
427's Avatar
Yes I do!
Kurt
Originally Posted by trans2000am
Kurt,
thanks
ryan
Old 09-23-2010, 10:37 PM
XtremeDime's Avatar
Yes I do!
Kurt
Are you Kurt Urban?? I was wondering that earlier lol
Old 09-24-2010, 08:18 AM
427's Avatar
I am!! official car junky for over 50 years!
Kurt
Old 12-02-2010, 03:28 PM
mdbreaux's Avatar
I am buying one of Kurt's systems right now. If you add up all the braided hoses, fittings, etc., you would not pay any less and his setup is very tight. Not to mention, I rather support someone who goes through all the trouble to make such nice items for people like us so we can just point, click, buy it, and bolt it on without all the headaches. Not to mention, Kurt is always accessible to communicate with and that is why I would seriously consider having him build my engine in the future.
Old 01-22-2012, 07:55 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I'm reviving this from the dead.... but it is a good thread to revive.
Is this setup, Kurt's in particular, something that could help save the ringlands on the back cylinders?
I have a FAST intake, and as such, had to block off the rear vent tubes, and last weekend I think I cracked #7's ringland.
Kurt, I'd like to hear your thoughts on this as I'm going to go with a forged shortblock, but I want to avoid this situation from ever happening again.
Thanks
Old 01-22-2012, 08:18 AM
427's Avatar
The thing that can happen is air gets trapped in the rear of the heads and insulates the backside of the combustion chamber on the rear cylinder causing hot spots. I believe this can lead to broken parts. I believe this is one problem that can cause issues in race engines and it's aggravated by running reduced water flow and water instead of coolant. I believe you also need to watch your water flow as the engine output gets into 4 digits.
Kurt
Thanks
Old 01-22-2012, 08:41 AM
7 Second Club
Kurt
Have you ever flow tested the airflow distribution on the factory manifolds to see if thats a portion of the problem? I've always wondered if the design of the factory manifold makes #7 more prone to higher volumes of airflow. On Brians car we found the air was doing some weird stuff at velocity.
Quick Reply: Water Vapor Collection system
