Got a decent shakedown run finally....
not that great but its my best so far, first passes I have gotten to make since building the current setup some 3 years ago without breaking something. I had almost zero seat time on this thing at the track.
ran couple of mid 10s at 145 ish, don't remember exactly... let the car cool, then ran this:
http://www.fquick.com/videos/Getting_there.../9921
or save as:
http://www.force-fed-fabrications.co.../mybestrun.wmv
I will confirm the full slip tomorrow, but off the top of my head it was 2.0 60 ft, 7.0 at 115 1/8, 10.3 at 153 1/4. DA was ~2600. It was nasty hot.
obviously the launch is lazy as hell. I was on the transbrake, and could only make about 2 lbs of boost, if I could get more like 5 lbs it would be much better.... the supra guys use nitrous for this reason lol, but I am wondering what else I can do to get 2-3 more lbs of boost on the brake before leaving?
Im happy to make some runs finally, look forward to about degrees cooler weather to go back out.
or save as:
no 2 step right now, not sure how that would help, I need to get the RPM's higher basically... I guess I could do yet another converter adjustment, but I really like the feel of this converter, specially on the top end
It'll work. Let some of the big names get in here and they will tell you the same thing. You will have to adjust timing and fuel when you are on the 2-step, but itll work.
Holy back half !!! Almost a 40 mph gain from the 1/8, holy **** !!!
A 2-step will allow you to go wot on the brake without the rpm's going to the moon.
From testing mine, going wot on the 2-step builds boost WAY sooner than a part throttle footbrake to a higher rpm.
I can go to 3,500rpm+ real quick foot braking it, but it builds boost sooner even with the 2-step set to only 2,500rpm with my foot to the floor.
Great passes Tiago! Good luck making more progress!
thanks guys, who's 2 step do you recommend?
I think I am only around 2500 RPM's on the brake, will confirm.
the tires are M&H drag radials 345/35/R18. They hook real good but they are tall, 29" tall I think, plus my 3.08 rear end, makes it kind of sluggish off the line, unless it has some boost!!!
Restricted User
I was using the ligenfelter unit up until recently. I just sold it because my new AEM computer has one built in. I liked the other one alot though. Very simple.
Is 2500 RPM as high as you can go on your converter? If so, do a log on the converter and see what area you are in in the timing table. You can run 30-40* at these low RPM's without detonation and it will help you to get up higher on the converter. If that doesn't work, you need to have the converter loosened up a little. You need to be able to get to 4K-4.5K on converter. Then you use the 2 step set below that to dial in your launch RPM. Then the boost controller dials in the launch boost.
good point on the timing, I need to look at this, I don't think I have enough timing in this area
