dumping oil out of exhaust after build
Old 09-22-2010, 04:47 PM
FasTimeSS's Avatar
Default dumping oil out of exhaust after build
got everything together car drives fine and idles
its just dumping and smoking oil out of the 5 inch exhaust. what could this be? blown turbo? its a pt88 with less than 2k miles on it.
i have a -4 oil feed line and a -8 oil return line.
i notice that if i rev the motor it smokes more.. if its sitting still there will be fresh oil all over the ground below the exhaust
Old 09-22-2010, 04:58 PM
XtremeDime's Avatar
My vote is for turbo seals
Old 09-22-2010, 05:06 PM
03supercobra's Avatar
For one thing, your oil return line should be bigger than -8. Are you running a scavenging pump? Could be turbo seals.
Old 09-22-2010, 05:08 PM
FasTimeSS's Avatar
called precision its the oil return. haha i need a -10 or -12 but im going into the timing cover. wat do yall think -10 or -12?
Old 09-22-2010, 05:10 PM
FasTimeSS's Avatar
i hope i didnt blow the seals but if i did its all good it should be much through precision
Run a -12, always better to go as big as possible.
Old 09-22-2010, 05:52 PM
FasTimeSS's Avatar
sounds good i cant find a flange for my turbo for the return for a -12 any help?
also is it possible i could of blown the seals on the turbo?
Old 09-22-2010, 05:57 PM
mike13's Avatar
I doubt it, turbo seals are more like thin washers then a actual lipped seal.
Old 09-22-2010, 06:33 PM
http://www.wolferacecraft.com/detail.aspx?ID=843
Old 09-22-2010, 06:45 PM
bad6as's Avatar
i run a -10 on mine no issues. also make sure the oil can flow good back to the pan
Old 09-22-2010, 08:11 PM
FasTimeSS's Avatar
im flowing to the timing cover.... so hopefully i can tap that bitch for 1/2'' instead of the -8 or watever i had
Old 09-22-2010, 11:57 PM
NBM-LS1's Avatar
I dont mean to highjack the thread but Im waiting for my turbo and I was wondering if my oil pressure (around 65-80psi cold) from my mehling oil pump is too much?
Old 09-23-2010, 12:11 AM
Johnv's Avatar
should be fine as long as you use -3or-4 feed line -12 return and plenty of fall for unrestricted flow back to the sump, and a decent crancase ventilation setup so your not pressurising the crankcase and therefore impedeing oilflow back to the sump.
Old 09-23-2010, 01:46 AM
NBM-LS1's Avatar
I dont think that is necessarily accurate. Im going to be running a breather setup. I don't feel like having oil all in my intake again. If im running oil pressure through the turbo there should be some pressure on the drain side. and If my crank case isn't sealed there isn't any way for it to build pressure in there. Does that sound correct?
Old 09-23-2010, 08:02 AM
mike13's Avatar
There really isn't any pressure on the drain side of the turbo once it goes thru the bearing section. If you follow the advice your getting you'll be fine. All he was saying is make sure to vent the pressure out of the motor.
Old 09-23-2010, 08:37 AM
Restricted User
98Z28CobraKiller's Avatar
I run a 3/4" female flange to a 3/4" to -12 male fitting. Got mine from Race Parts Solutions.
Old 09-23-2010, 10:18 AM
Fireball's Avatar
bigger is always better here...
-12
Old 09-23-2010, 11:06 AM
KRAZY K 2000 TA's Avatar
any pics of how you have it setup?
Old 09-23-2010, 12:23 PM
FasTimeSS's Avatar
ill get pics tonight, cobra, can you get me a link on that setup. i have a 1/2'' flange from ebay for the return. some ghetto **** from ebay it doesnt seal up very good. is it ok to rtv the **** outta that flange? or should i use a gasket?
Old 09-23-2010, 05:26 PM
t-1
t-1's Avatar
me too
Quick Reply: dumping oil out of exhaust after build
