Yellow springs survive .550" Z06 cam w/boost?
Old 09-23-2010, 11:58 AM
00Wildcat's Avatar
Default Yellow springs survive .550" Z06 cam w/boost?
Swapping a stock '04 5.3 into a '79 Malibu as a daily driver w/ intentions of budget TT after I get a rearend in the car and fresh paint. I want to change the cam and already have a new set of yellow z06 springs and moly stock lenth pushrods. Will the springs be strong enough to keep the intake valve seated with boost?
Old 09-23-2010, 12:00 PM
JAX04's Avatar
i floated mine sometime after 8lbs, not sure when, as it went straight to 14
Old 09-23-2010, 12:08 PM
XtremeDime's Avatar
I ran yellows on 8psi no problem. Im still running the stock cam though.
Old 09-23-2010, 12:17 PM
00Wildcat's Avatar
no max effort deal just want the engine to hold up to daily driving + enough power to spank most real modern street cars 450-500 RWHP sort of thing. I don't want to spin it 6000+ anything over 5500 all the time is border line abusive. 8-10 psi on small twins is max. twins on g-body with a/c probably easier to plumb than single 70mm t04
Old 09-23-2010, 12:45 PM
buick_lsx's Avatar
im on 9lbs with no float so far
Old 09-23-2010, 02:10 PM
00Wildcat's Avatar
"Buick" .550 lift Z06 cam and springs?
Old 09-23-2010, 02:14 PM
buick_lsx's Avatar
ls6 cam and the ls1/6 yellows
Old 09-23-2010, 02:17 PM
HydroStream6's Avatar
If they are already installed leave them. If they're not installed I'd invest in something a little beefier.
Old 09-23-2010, 03:25 PM
Restricted User
98Z28CobraKiller's Avatar
I hit mine with 15 psi without any float. I was only spinning to 6100-6200 but it never floated.
Old 09-23-2010, 05:53 PM
00Wildcat's Avatar
cobrakiller: are you running z06 cam/springs w/pt88 on 6.0L?
Old 09-23-2010, 06:45 PM
7 Second Club
NicD's Avatar
It all depends on the turbo selection and how much hot side back pressure you are going to have. The last LS6 cammed 5.7L I saw had an MPT-70 and it started floating them around 7 psi.
Old 09-24-2010, 04:00 AM
Zombie's Avatar
I wouldn't do it personally, risk / reward isn't in a ratio I like. Much better to do it once if you know what will work.
BTW, we all start out saying I'll only go to XX PSI. When I got my car I said no more than 8psi..... You will end up feeding the addiction, you are not special.
Old 09-24-2010, 09:14 AM
Restricted User
Not anymore. When I first built the turbo kit, I used a bone stock longblock with the yellow springs on the 317 heads and the stock LQ9 cam.
Now I have a forged bottom with AFR225's with the upgraded springs and a 232/232 cam.
Old 09-24-2010, 11:43 AM
00Wildcat's Avatar
least expensive springs that will do the job w/.550" z06 cam and boost? The new yellow springs that I have came on LS9 prototype heads, if they will work with sightly more aggressive ZR1/LS9 cam and blower why not z06/turbo combo? Of course truck heads have steel valves and LS9 heads are ti intake/sodium filled exhuast (lighter).
Quick Reply: Yellow springs survive .550" Z06 cam w/boost?
