Help Needed, starts but wont run
Old 09-24-2010, 08:48 PM
020NN20's Avatar
Default Help Needed, starts but wont run
Ok, so I have built a turbo transam, DIY truck manifold kit, tc78, proflo intake, nice 317 heads, full fuel system. The day I finished it, my friend and I started it up, car fired right over, idled smoothly, for the cam thats in it, had good throttle response, everything great. Had a small fuel leak, shut the car off, repaired the problem, started it again, ran REALLY rough, but didnt die, rev'd it a little, and still when it came down didnt die. Shut if off again(another fuel leak). NOW all it does is start, and shut off, maybe 3-5 seconds run time....WTF!!!!!!!!!! If I try to give the car throttle while starting it, it kills it quicker, doesnt loose fuel pressure, shows 9-11 in. of vacuum when it fires, dies off when the car dies... Going crazy, has fuel, has spark, has a tune for the fuel system and turbo in it....I DONT GET IT, what the hell happened??? Im really gettin fed up...dont know what to do anymore guys... any help would be appreciated. Thanks, Dennis
Old 09-25-2010, 08:45 AM
Restricted User
98Z28CobraKiller's Avatar
When you say fuel leak, we talking a tiny drip or a stream of fuel? Where were the leaks? What cam is in there that you are only seeing 9-11 in of vacuum? Maybe you accidentaly pulled off a vacuum line when fixing the fuel leak? How's voltage?
Old 09-25-2010, 09:39 AM
ND400's Avatar
did you put a 2bar map sensor in it?
Old 09-25-2010, 10:34 AM
Jeremy Walker's Avatar
These were my first thoughts
Old 09-25-2010, 11:23 AM
Taubr Unit's Avatar
the car is actually in my driveway and i helped build it up. The fuel leak was just drips but thats all fixed now and no leaks, the cam is a Speed Inc TU2 turbo cam and we went through all the vacuum lines like 10 times and nothing, no rips tears etc..
yes it has a 2-bar MAP on it
Now like he said if we keep the throttle blade shut it kinda idles for about 8-10 seconds but its a REALLY rough idle, if you WOT and start it, it fires up to about 3k rpm then dies instantly. So more throttle is worse then closed.
Old 09-25-2010, 12:25 PM
Taubr Unit's Avatar
heres the vid after it idled pretty good, this is the wanna-be blower motor, lol.
http://www.youtube.com/watch?v=wFWlNUKG1Bc
Old 09-25-2010, 12:36 PM
Taubr Unit's Avatar
heres the kit, dunno if it helps out or not...
Old 09-25-2010, 01:34 PM
Restricted User
transammiller's Avatar
hey I've seen that TB coupler before. lol
Old 09-25-2010, 01:38 PM
Taubr Unit's Avatar
heres what its doin now...
http://www.youtube.com/watch?v=cm6zmiDGJ4g
Old 09-25-2010, 02:41 PM
Johnv's Avatar
do you have bigger injectors ?
has the tune been modified to take into account big injectors and rescaled for the 2 bar MAP sensor ?
You could put the std MAP sensor and injectors back in just to start it and trouble shoot leeks etc, but don't drive in boost !!!
Old 09-25-2010, 02:46 PM
Taubr Unit's Avatar
yea, Speed Inc. flashed the computer with a run file for the injectors, MAP, speed density etc. We unplugged the MAP and it would start up but not try and catch the idle, plugged it back in and then it would try to catch itself but still cant. I have a stock PCM for my car and we plugged that in (stock PCM from a f-body) and it does the exact same thing, no change in anything which i thought was kinda weird. Pulled every plug wire off and everyone has spark, pulled off the main feed line and it pours out like a garden hose, pulled off the elbow to run it on "motor" and no change. No matter what we try, unplug, change etc we cant get it to do ANYTHING different.
Old 09-25-2010, 04:54 PM
Flaco's Avatar
i would have to say tune related...
Old 09-25-2010, 05:11 PM
020NN20's Avatar
It pretty much cant be tune related...It does the same EXACT thing on a tuned and untuned computer....speed inc. is one of the best in chicagoland with turbo fbodys....and it doesnt change it a bit....Im thinkin its a huuuuuge vacuum leak, more than likely coming from the intake again....intake looks great, and makes great power according to a lot of people....imma bring it in for scrap if i have to pull it off again...
Old 09-25-2010, 06:42 PM
BLK02WS6's Avatar
You absolutely sure they changed the MAP scaler in the tune for the 2 bar sensor? If it's doing the same thing with a stock computer (which wouldn't be scaled for a 2 bar), then I would look at that first... don't care how many they do, there is always the chance a mistake was made...
Old 09-25-2010, 06:54 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
If you can't hold the idle at 1500 rpms by hand, that will give you some things to think about. Do you have anything plugged in to look at your L trims, and to see if anything is going on with respect to adding/pulling fuel? Have you verified that base fuel pressure is holding?
Old 09-25-2010, 06:57 PM
LS1Tech Co-Founder
Just watched the vid. I'm assuming you've check stuff like making sure that the injector harness is plugged in and undamaged, but since it won't run on any cylinders I'd be looking into the fuel system, and maybe also make sure the crank sensor harness is not messed up.
Old 09-25-2010, 07:18 PM
Taubr Unit's Avatar
well we hooked up my home-made pressurized tester to simulate boost and we have air leaking around all 8 injector bases. We sprayed soapy water around um and they bubble up like crazy so assuming its a big time vacuum leak from that. If not it had to be fixed anyways.
Old 09-25-2010, 08:15 PM
Restricted User
I don't think that's your problem here. You sure you have gasoline getting in the holes? It doesn't sound like it. Do you have the ability to scan? If the TPS isn't reading currectly, it will throw the computer into clear flood which means no fuel and will display 100% on a scan.
Old 09-25-2010, 09:19 PM
Taubr Unit's Avatar
as of right now we dont have a scan tool, can prob get one during the week to check some things out. We do have a xtra TPS we can swap out and see if that helps. Reguardess the injectors need to be sealed up. When we put only about 5psi in the intake it blows air outta um really bad. I can hear um leak air from across the garage. It just blows our mind that it started up the first time without missing a beat and idled pretty damn good, now this? Thats the biggest kick in the *****
Old 09-25-2010, 09:26 PM
mike13's Avatar
Did you pull the injectors to fix the leaks?
Quick Reply: Help Needed, starts but wont run
